FCesiumPropertyAttributePropertyDescription Struct Reference
Description of a property attribute property that should be encoded for access on the GPU. More...
#include <CesiumFeaturesMetadataDescription.h>
FString Name
 The name of this property.
FCesiumMetadataPropertyDetails PropertyDetails
 Describes the underlying type of this property and other relevant information from its EXT_structural_metadata definition.
FCesiumMetadataEncodingDetails EncodingDetails
 Describes how the property will be encoded as data on the GPU, if possible.
This is similar to FCesiumPropertyTablePropertyDescription, but is limited to the types that are supported for property attribute properties.
Definition at line 249 of file CesiumFeaturesMetadataDescription.h.
◆ EncodingDetails
FCesiumMetadataEncodingDetails FCesiumPropertyAttributePropertyDescription::EncodingDetails
Definition at line 271 of file CesiumFeaturesMetadataDescription.h.
◆ Name
FString FCesiumPropertyAttributePropertyDescription::Name
This will be how it is referenced in the material.
Definition at line 257 of file CesiumFeaturesMetadataDescription.h.
◆ PropertyDetails
FCesiumMetadataPropertyDetails FCesiumPropertyAttributePropertyDescription::PropertyDetails
Not all types of properties can be encoded to the GPU, or coerced to GPU-compatible types.
Definition at line 265 of file CesiumFeaturesMetadataDescription.h.
