ACesiumCartographicPolygon Class Reference
A spline-based polygon actor used to rasterize 2D polygons on top of Cesium 3D Tileset actors. More...
#include <CesiumCartographicPolygon.h>
Inheritance diagram for ACesiumCartographicPolygon:
 ACesiumCartographicPolygon ()
virtual void OnConstruction (const FTransform &Transform) override
CesiumGeospatial::CartographicPolygon CreateCartographicPolygon (const FTransform &worldToTileset) const
 Creates and returns a CartographicPolygon object created from the current spline selection.
void SetPolygonPoints (const ECesiumCoordinateReferenceSystem CoordinateReferenceSystem, const TArray< FVector > &Points)
 Sets the spline points from an array of positions in the specified coordinate reference system.
virtual void PostLoad () override
USplineComponent * Polygon
 The polygon.
UCesiumGlobeAnchorComponent * GlobeAnchor
 The Globe Anchor Component that precisely ties this Polygon to the Globe.
Protected Member Functions
virtual void BeginPlay () override
Definition at line 37 of file CesiumCartographicPolygon.h.
◆ ACesiumCartographicPolygon()
ACesiumCartographicPolygon::ACesiumCartographicPolygon ( )
◆ BeginPlay()
virtual void ACesiumCartographicPolygon::BeginPlay ( )
overrideprotectedvirtual
◆ CreateCartographicPolygon()
CesiumGeospatial::CartographicPolygon ACesiumCartographicPolygon::CreateCartographicPolygon ( const FTransform & worldToTileset) const
worldToTilesetThe transformation from Unreal world coordinates to the coordinates of the Cesium3DTileset Actor for which the cartographic polygon is being created.
◆ OnConstruction()
virtual void ACesiumCartographicPolygon::OnConstruction ( const FTransform & Transform)
overridevirtual
◆ PostLoad()
virtual void ACesiumCartographicPolygon::PostLoad ( )
overridevirtual
◆ SetPolygonPoints()
void ACesiumCartographicPolygon::SetPolygonPoints ( const ECesiumCoordinateReferenceSystem CoordinateReferenceSystem,
const TArray< FVector > & Points )
CoordinateReferenceSystemThe coordinate reference system in which the points are expressed.
PointsThe array of points expressed in the specified coordinate system.
◆ GlobeAnchor
UCesiumGlobeAnchorComponent* ACesiumCartographicPolygon::GlobeAnchor
Definition at line 54 of file CesiumCartographicPolygon.h.
◆ Polygon
USplineComponent* ACesiumCartographicPolygon::Polygon
The polygon.
Definition at line 48 of file CesiumCartographicPolygon.h.
