CesiumTilesetJson::FoundMetadataProperty Struct Reference
Holds the details of a found property in a MetadataEntity. More...
#include <CesiumTilesetJson/MetadataQuery.h>
const std::string & classIdentifier
 A reference to the identifier of the class that contains the found property within the Schema.
const Class & classDefinition
 A reference to the Class that contains the found property within the Schema.
const std::string & propertyIdentifier
 A reference to the identifier of the found property within the Schema.
const ClassProperty & propertyDefinition
 A reference to the ClassProperty describing the found property within the Schema.
const CesiumUtility::JsonValue & propertyValue
 A reference to the value of the found property within the MetadataEntity.
Because this structure holds references to the original Schema and MetadataEntity instances, it will be invalidated if either are destroyed or modified. Continuing to access this result in that scenario will result in undefined behavior.
Definition at line 20 of file MetadataQuery.h.
◆ classDefinition
const Class& CesiumTilesetJson::FoundMetadataProperty::classDefinition
Definition at line 31 of file MetadataQuery.h.
◆ classIdentifier
const std::string& CesiumTilesetJson::FoundMetadataProperty::classIdentifier
Definition at line 25 of file MetadataQuery.h.
◆ propertyDefinition
const ClassProperty& CesiumTilesetJson::FoundMetadataProperty::propertyDefinition
Definition at line 43 of file MetadataQuery.h.
◆ propertyIdentifier
const std::string& CesiumTilesetJson::FoundMetadataProperty::propertyIdentifier
Definition at line 37 of file MetadataQuery.h.
◆ propertyValue
const CesiumUtility::JsonValue& CesiumTilesetJson::FoundMetadataProperty::propertyValue
Definition at line 49 of file MetadataQuery.h.
