CesiumTilesetJson::ClassProperty Struct Referencefinal
A single property of a metadata class. More...
#include <CesiumTilesetJson/ClassProperty.h>
Inheritance diagram for CesiumTilesetJson::ClassProperty:
Classes
struct  ComponentType
 Known values for The datatype of the element's components. Required for SCALAR, VECN, and MATN types, and disallowed for other types. More...
struct  Type
 Known values for The element type. More...
 The name of the property, e.g. for display purposes.
 The description of the property.
std::string type = Type::SCALAR
 The element type.
std::optional< std::string > componentType
std::optional< std::string > enumType
 Enum ID as declared in the enums dictionary. Required when type is ENUM. Disallowed when type is not ENUM
bool array = false
 Whether the property is an array. When count is defined the property is a fixed-length array. Otherwise the property is a variable-length array.
std::optional< int64_t > count
 The number of array elements. May only be defined when array is true.
bool normalized = false
 Specifies whether integer values are normalized. Only applicable to SCALAR, VECN, and MATN types with integer component types. For unsigned integer component types, values are normalized between [0.0, 1.0]. For signed integer component types, values are normalized between [-1.0, 1.0]. For all other component types, this property shall be false.
std::optional< CesiumUtility::JsonValue > offset
 An offset to apply to property values. Only applicable to SCALAR, VECN, and MATN types when the component type is FLOAT32 or FLOAT64, or when the property is normalized. Not applicable to variable-length arrays.
std::optional< CesiumUtility::JsonValue > scale
 A scale to apply to property values. Only applicable to SCALAR, VECN, and MATN types when the component type is FLOAT32 or FLOAT64, or when the property is normalized. Not applicable to variable-length arrays.
std::optional< CesiumUtility::JsonValue > max
 Maximum allowed value for the property. Only applicable to SCALAR, VECN, and MATN types. This is the maximum of all property values, after the transforms based on the normalized, offset, and scale properties have been applied. Not applicable to variable-length arrays.
std::optional< CesiumUtility::JsonValue > min
 Minimum allowed value for the property. Only applicable to SCALAR, VECN, and MATN types. This is the minimum of all property values, after the transforms based on the normalized, offset, and scale properties have been applied. Not applicable to variable-length arrays.
bool required = false
 If required, the property shall be present in every entity conforming to the class. If not required, individual entities may include noData values, or the entire property may be omitted. As a result, noData has no effect on a required property. Client implementations may use required properties to make performance optimizations.
std::optional< CesiumUtility::JsonValue > noData
 A noData value represents missing data — also known as a sentinel value — wherever it appears. BOOLEAN properties may not specify noData values. This is given as the plain property value, without the transforms from the normalized, offset, and scale properties. Shall not be defined if required is true.
std::optional< CesiumUtility::JsonValue > defaultProperty
 A default value to use when encountering a noData value or an omitted property. The value is given in its final form, taking the effect of normalized, offset, and scale properties into account. Shall not be defined if required is true.
std::optional< std::string > semantic
 An identifier that describes how this property should be interpreted. The semantic cannot be used by other properties in the class.
static constexpr const char * TypeName = "ClassProperty"
Definition at line 17 of file ClassProperty.h.
int64_t CesiumTilesetJson::ClassProperty::getSizeBytes ( ) const
Definition at line 221 of file ClassProperty.h.
◆ array
bool CesiumTilesetJson::ClassProperty::array = false
Definition at line 133 of file ClassProperty.h.
◆ componentType
std::optional<std::string> CesiumTilesetJson::ClassProperty::componentType
Known values are defined in ComponentType.
Definition at line 120 of file ClassProperty.h.
◆ count
std::optional<int64_t> CesiumTilesetJson::ClassProperty::count
Definition at line 139 of file ClassProperty.h.
◆ defaultProperty
std::optional<CesiumUtility::JsonValue> CesiumTilesetJson::ClassProperty::defaultProperty
Definition at line 207 of file ClassProperty.h.
◆ description
std::optional<std::string> CesiumTilesetJson::ClassProperty::description
Definition at line 103 of file ClassProperty.h.
◆ enumType
std::optional<std::string> CesiumTilesetJson::ClassProperty::enumType
Definition at line 126 of file ClassProperty.h.
◆ max
std::optional<CesiumUtility::JsonValue> CesiumTilesetJson::ClassProperty::max
Definition at line 173 of file ClassProperty.h.
◆ min
std::optional<CesiumUtility::JsonValue> CesiumTilesetJson::ClassProperty::min
Definition at line 181 of file ClassProperty.h.
◆ name
std::optional<std::string> CesiumTilesetJson::ClassProperty::name
Definition at line 98 of file ClassProperty.h.
◆ noData
std::optional<CesiumUtility::JsonValue> CesiumTilesetJson::ClassProperty::noData
Definition at line 199 of file ClassProperty.h.
◆ normalized
bool CesiumTilesetJson::ClassProperty::normalized = false
Definition at line 149 of file ClassProperty.h.
◆ offset
std::optional<CesiumUtility::JsonValue> CesiumTilesetJson::ClassProperty::offset
Definition at line 157 of file ClassProperty.h.
◆ required
bool CesiumTilesetJson::ClassProperty::required = false
Definition at line 190 of file ClassProperty.h.
◆ scale
std::optional<CesiumUtility::JsonValue> CesiumTilesetJson::ClassProperty::scale
Definition at line 165 of file ClassProperty.h.
◆ semantic
std::optional<std::string> CesiumTilesetJson::ClassProperty::semantic
Definition at line 213 of file ClassProperty.h.
◆ type
std::string CesiumTilesetJson::ClassProperty::type = Type::SCALAR
The element type.
Definition at line 111 of file ClassProperty.h.
const char* CesiumTilesetJson::ClassProperty::TypeName = "ClassProperty"
Definition at line 22 of file ClassProperty.h.
