A class containing a set of properties.
More...
#include <CesiumTilesetJson/Class.h>
| | Calculates the size in bytes of this object, including the contents of all collections, pointers, and strings. This will NOT include the size of any extensions attached to the object. Calling this method may be slow as it requires traversing the object's entire structure.
| template<typename T> |
| | Checks if an extension exists given its static type.
| | Gets an extension given its static type.
| | Gets a generic extension with the given name as a CesiumUtility::JsonValue.
| template<typename T, typename... ConstructorArgumentTypes> |
| | Adds a statically-typed extension to this object.
| | Removes a statically-typed extension from this object.
| | Calculates the size in bytes of this ExtensibleObject, including all of its extras but NOT including its extensions. Calling this method may be slow as it requires traversing the entire object.
| | The name of the class, e.g. for display purposes.
| std::optional< std::string > | description |
| | The description of the class.
| std::unordered_map< std::string, CesiumTilesetJson::ClassProperty > | properties |
| | A dictionary, where each key is a property ID and each value is an object defining the property. Property IDs shall be alphanumeric identifiers matching the regular expression ^[a-zA-Z_][a-zA-Z0-9_]*$.
| std::optional< std::string > | parent |
| | Experimental. The parent class ID.
| | The extensions attached to this object.
| | Application-specific data.
| | Unknown properties that exist on this object but do not have any representation in the statically-typed classes.
| static constexpr const char * | TypeName = "Class" |
| | The original name of this type.
Definition at line 17 of file Class.h.
◆ getSizeBytes()
| int64_t CesiumTilesetJson::Class::getSizeBytes |
const |
Definition at line 52 of file Class.h.
◆ description
| std::optional<std::string> CesiumTilesetJson::Class::description |
Definition at line 32 of file Class.h.
◆ name
| std::optional<std::string> CesiumTilesetJson::Class::name |
Definition at line 27 of file Class.h.
◆ parent
| std::optional<std::string> CesiumTilesetJson::Class::parent |
Definition at line 44 of file Class.h.
◆ properties
Definition at line 39 of file Class.h.
◆ TypeName
| const char* CesiumTilesetJson::Class::TypeName = "Class" |
Definition at line 22 of file Class.h.
- /home/runner/work/cesium-native/cesium-native/CesiumTilesetJson/generated/include/CesiumTilesetJson/Class.h
