cesium-native 0.67.0
External metadata schema that describes the structure and validation rules for properties found in GeoJSON features within 3D Tiles content. This schema defines the expected property names, data types, constraints, and semantics that should be present in the 'properties' object of GeoJSON Feature objects. More...
#include <CesiumTilesetJson/ExtensionSchemaMaxarContentGeoJson.h>
| Human readable name for the properties schema. | |
| std::string | semantic |
| A high-level identifier that define the meaning of the properties. Recommended best practice is to select a value from a controlled vocabulary or formal classification scheme. | |
| CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJsonGeometryValue | geometry |
| geometry | |
| std::vector< CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJsonPropertiesValue > | properties |
| An array of property definitions that correspond to the properties found in GeoJSON Feature objects. Each definition describes a property that may appear in the 'properties' field of GeoJSON features within the associated tile content. Each property's semantic value must be unique within the array. | |
| static constexpr const char * | TypeName = "ExtensionSchemaMaxarContentGeoJson" |
| static constexpr const char * | ExtensionName = "MAXAR_content_geojson" |
Definition at line 22 of file ExtensionSchemaMaxarContentGeoJson.h.
Definition at line 66 of file ExtensionSchemaMaxarContentGeoJson.h.
Definition at line 30 of file ExtensionSchemaMaxarContentGeoJson.h.
| CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJsonGeometryValue CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJson::geometry |
geometry
Definition at line 47 of file ExtensionSchemaMaxarContentGeoJson.h.
| std::optional<std::string> CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJson::name |
Definition at line 35 of file ExtensionSchemaMaxarContentGeoJson.h.
| std::vector< CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJsonPropertiesValue> CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJson::properties |
Definition at line 58 of file ExtensionSchemaMaxarContentGeoJson.h.
| std::string CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJson::semantic |
Definition at line 42 of file ExtensionSchemaMaxarContentGeoJson.h.
Definition at line 27 of file ExtensionSchemaMaxarContentGeoJson.h.
