CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJsonGeometryValue Struct Referencefinal
ExtensionSchemaMaxarContentGeoJson Geometry Value. More...
#include <CesiumTilesetJson/ExtensionSchemaMaxarContentGeoJsonGeometryValue.h>
Inheritance diagram for CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJsonGeometryValue:
Classes
struct  Type
 Known values for Type of GeoJSON geometry inside the group. More...
std::string type = Type::Point
int64_t dimensions = int64_t()
 2D or 3D geometries
int64_t CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJsonGeometryValue::getSizeBytes ( ) const
Definition at line 65 of file ExtensionSchemaMaxarContentGeoJsonGeometryValue.h.
◆ dimensions
int64_t CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJsonGeometryValue::dimensions = int64_t()
2D or 3D geometries
Definition at line 57 of file ExtensionSchemaMaxarContentGeoJsonGeometryValue.h.
◆ type
std::string CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJsonGeometryValue::type = Type::Point
Definition at line 52 of file ExtensionSchemaMaxarContentGeoJsonGeometryValue.h.
const char* CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJsonGeometryValue::TypeName
Initial value:
"ExtensionSchemaMaxarContentGeoJsonGeometryValue"
Definition at line 20 of file ExtensionSchemaMaxarContentGeoJsonGeometryValue.h.
