CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJsonPropertiesValue Struct Referencefinal
ExtensionSchemaMaxarContentGeoJson Properties Value. More...
#include <CesiumTilesetJson/ExtensionSchemaMaxarContentGeoJsonPropertiesValue.h>
Inheritance diagram for CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJsonPropertiesValue:
Classes
struct  Type
 Known values for Expected datatype of the property value in the GeoJSON Feature's 'properties' object. More...
std::string id
 Unique property identifier that corresponds to a property name in the GeoJSON Feature's 'properties' object.
std::string type = Type::Integer
 Human readable description of the property.
std::optional< std::string > unit
 Unit of the specified property.
std::optional< double > max
 Maximum allowed value for the property. Only applicable to integer and float types. When both min and max are specified, max must be greater than or equal to min.
std::optional< double > min
 Minimum allowed value for the property. Only applicable to integer and float types. When both min and max are specified, min must be less than or equal to max.
std::optional< bool > required = std::optional<bool>()
 If true, this property must be present in the 'properties' object of every GeoJSON Feature in the associated tile content.
std::optional< CesiumUtility::JsonValue > defaultProperty
 A default value to use when this property is missing from a GeoJSON Feature's 'properties' object. Shall not be defined if required is true.
std::optional< std::string > semantic
 An identifier that describes how this property should be interpreted. The semantic cannot be used by other properties in the properties schema.
int64_t CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJsonPropertiesValue::getSizeBytes ( ) const
Definition at line 109 of file ExtensionSchemaMaxarContentGeoJsonPropertiesValue.h.
◆ defaultProperty
std::optional<CesiumUtility::JsonValue> CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJsonPropertiesValue::defaultProperty
Definition at line 94 of file ExtensionSchemaMaxarContentGeoJsonPropertiesValue.h.
◆ description
std::optional<std::string> CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJsonPropertiesValue::description
Definition at line 63 of file ExtensionSchemaMaxarContentGeoJsonPropertiesValue.h.
◆ id
std::string CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJsonPropertiesValue::id
Definition at line 49 of file ExtensionSchemaMaxarContentGeoJsonPropertiesValue.h.
◆ max
std::optional<double> CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJsonPropertiesValue::max
Definition at line 75 of file ExtensionSchemaMaxarContentGeoJsonPropertiesValue.h.
◆ min
std::optional<double> CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJsonPropertiesValue::min
Definition at line 82 of file ExtensionSchemaMaxarContentGeoJsonPropertiesValue.h.
◆ required
std::optional<bool> CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJsonPropertiesValue::required = std::optional<bool>()
Definition at line 88 of file ExtensionSchemaMaxarContentGeoJsonPropertiesValue.h.
◆ semantic
std::optional<std::string> CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJsonPropertiesValue::semantic
Definition at line 101 of file ExtensionSchemaMaxarContentGeoJsonPropertiesValue.h.
◆ type
std::string CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJsonPropertiesValue::type = Type::Integer
Definition at line 58 of file ExtensionSchemaMaxarContentGeoJsonPropertiesValue.h.
const char* CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJsonPropertiesValue::TypeName
Initial value:
"ExtensionSchemaMaxarContentGeoJsonPropertiesValue"
Definition at line 21 of file ExtensionSchemaMaxarContentGeoJsonPropertiesValue.h.
◆ unit
std::optional<std::string> CesiumTilesetJson::ExtensionSchemaMaxarContentGeoJsonPropertiesValue::unit
Definition at line 68 of file ExtensionSchemaMaxarContentGeoJsonPropertiesValue.h.
