ExtensionSchemaMaxarContentGeoJson.h
5#include <Cesium3DTiles/ExtensionSchemaMaxarContentGeoJsonGeometryValue.h>
6#include <Cesium3DTiles/ExtensionSchemaMaxarContentGeoJsonPropertiesValue.h>
7#include <Cesium3DTiles/Library.h>
8#include <CesiumUtility/ExtensibleObject.h>
9
10#include <optional>
11#include <string>
12#include <vector>
13
14namespace Cesium3DTiles {
22struct CESIUM3DTILES_API ExtensionSchemaMaxarContentGeoJson final
27 static constexpr const char* TypeName = "ExtensionSchemaMaxarContentGeoJson";
30 static constexpr const char* ExtensionName = "MAXAR_content_geojson";
31
35 std::optional<std::string> name;
36
42 std::string semantic;
43
48
56 std::vector<Cesium3DTiles::ExtensionSchemaMaxarContentGeoJsonPropertiesValue>
58
65 int64_t getSizeBytes() const {
66 int64_t accum = 0;
67 accum += int64_t(sizeof(ExtensionSchemaMaxarContentGeoJson));
69 int64_t(sizeof(CesiumUtility::ExtensibleObject));
70 if (this->name) {
71 accum += int64_t(this->name->capacity() * sizeof(char));
72 }
73 accum += int64_t(this->semantic.capacity() * sizeof(char));
74 accum +=
75 this->geometry.getSizeBytes() -
76 int64_t(sizeof(
78 accum += int64_t(
79 sizeof(
81 this->properties.capacity());
83 value : this->properties) {
84 accum += value.getSizeBytes() -
85 int64_t(sizeof(
88 }
89 return accum;
90 }
91};
92} // namespace Cesium3DTiles
Classes for using 3D Tiles.
Definition Buffer.h:7
External metadata schema that describes the structure and validation rules for properties found in Ge...
Cesium3DTiles::ExtensionSchemaMaxarContentGeoJsonGeometryValue geometry
geometry
Human readable name for the properties schema.
std::vector< Cesium3DTiles::ExtensionSchemaMaxarContentGeoJsonPropertiesValue > properties
An array of property definitions that correspond to the properties found in GeoJSON Feature objects....
A high-level identifier that define the meaning of the properties. Recommended best practice is to se...
