CesiumGltf::NormalFromAccessor Struct Reference
Visitor that retrieves the normal from the given accessor type as a glm::dvec3. More...
#include <CesiumGltf/AccessorUtility.h>
std::optional< glm::dvec3 > operator() (const AccessorView< AccessorTypes::VEC3< T > > &value)
 Attempts to obtain a glm::dvec3 at the given index from an accessor over a vec3. The values will be cast to double and, if applicable, normalized based on std::numeric_limits<T>::max(). If the index is invalid, std::nullopt is returned instead.
int64_t index
 The index of the normal to obtain.
There are technically no invalid normal values, so std::nullopt is used to denote an erroneous value.
Definition at line 153 of file AccessorUtility.h.
◆ operator()()
std::optional< glm::dvec3 > CesiumGltf::NormalFromAccessor::operator() ( const AccessorView< AccessorTypes::VEC3< T > > & value)
Definition at line 162 of file AccessorUtility.h.
◆ index
int64_t CesiumGltf::NormalFromAccessor::index
Definition at line 181 of file AccessorUtility.h.
