CesiumGltf::IndicesForFaceFromAccessor Struct Reference
Visitor that retrieves the vertex indices from the given accessor type corresponding to a given face index. These indices are returned as an array of int64_ts. This should be initialized with the index of the face, the total number of vertices in the primitive, and the CesiumGltf::MeshPrimitive::Mode of the primitive. More...
#include <CesiumGltf/AccessorUtility.h>
std::array< int64_t, 3 > operator() (std::monostate)
 Attempts to obtain the indices for the given face from an empty accessor variant, using the vertexCount property.
std::array< int64_t, 3 > operator() (const AccessorView< T > &value)
 Attempts to obtain the indices for the given face from an AccessorView, using the view's size and contents rather than the vertexCount property.
int64_t faceIndex
 The index of the face to obtain indices for.
int64_t vertexCount
 The total number of vertices in the data being accessed.
int32_t primitiveMode
 The MeshPrimitive::Mode of the data being accessed.
-1 is used to indicate errors retrieving the index, e.g., if the given index was out-of-bounds.
Definition at line 352 of file AccessorUtility.h.
◆ operator()() [1/2]
std::array< int64_t, 3 > CesiumGltf::IndicesForFaceFromAccessor::operator() ( const AccessorView< T > & value)
Definition at line 401 of file AccessorUtility.h.
◆ operator()() [2/2]
std::array< int64_t, 3 > CesiumGltf::IndicesForFaceFromAccessor::operator() ( std::monostate )
Definition at line 355 of file AccessorUtility.h.
◆ faceIndex
int64_t CesiumGltf::IndicesForFaceFromAccessor::faceIndex
Definition at line 448 of file AccessorUtility.h.
◆ primitiveMode
int32_t CesiumGltf::IndicesForFaceFromAccessor::primitiveMode
Definition at line 452 of file AccessorUtility.h.
◆ vertexCount
int64_t CesiumGltf::IndicesForFaceFromAccessor::vertexCount
Definition at line 450 of file AccessorUtility.h.
