CesiumGltf::MeshPrimitive::Mode Struct Reference
Known values for The topology type of primitives to render. More...
#include <CesiumGltf/MeshPrimitive.h>
static constexpr int32_t POINTS = 0
 POINTS (0)
static constexpr int32_t LINES = 1
 LINES (1)
static constexpr int32_t LINE_LOOP = 2
 LINE_LOOP (2)
static constexpr int32_t LINE_STRIP = 3
 LINE_STRIP (3)
static constexpr int32_t TRIANGLES = 4
 TRIANGLES (4)
static constexpr int32_t TRIANGLE_STRIP = 5
 TRIANGLE_STRIP (5)
static constexpr int32_t TRIANGLE_FAN = 6
 TRIANGLE_FAN (6)
Definition at line 27 of file MeshPrimitive.h.
◆ LINE_LOOP
int32_t CesiumGltf::MeshPrimitive::Mode::LINE_LOOP = 2
LINE_LOOP (2)
Definition at line 35 of file MeshPrimitive.h.
◆ LINE_STRIP
int32_t CesiumGltf::MeshPrimitive::Mode::LINE_STRIP = 3
LINE_STRIP (3)
Definition at line 38 of file MeshPrimitive.h.
◆ LINES
int32_t CesiumGltf::MeshPrimitive::Mode::LINES = 1
LINES (1)
Definition at line 32 of file MeshPrimitive.h.
◆ POINTS
int32_t CesiumGltf::MeshPrimitive::Mode::POINTS = 0
POINTS (0)
Definition at line 29 of file MeshPrimitive.h.
◆ TRIANGLE_FAN
int32_t CesiumGltf::MeshPrimitive::Mode::TRIANGLE_FAN = 6
TRIANGLE_FAN (6)
Definition at line 47 of file MeshPrimitive.h.
◆ TRIANGLE_STRIP
int32_t CesiumGltf::MeshPrimitive::Mode::TRIANGLE_STRIP = 5
TRIANGLE_STRIP (5)
Definition at line 44 of file MeshPrimitive.h.
◆ TRIANGLES
int32_t CesiumGltf::MeshPrimitive::Mode::TRIANGLES = 4
TRIANGLES (4)
Definition at line 41 of file MeshPrimitive.h.
