CesiumGltf::File Struct Referencefinal
A reference to an external file. Files MAY be referenced by a URI (or IRI) or a buffer view index. More...
#include <CesiumGltf/File.h>
Inheritance diagram for CesiumGltf::File:
Classes
struct  MimeType
 Known values for The media type or MIME type of the external file. More...
std::vector< CesiumGltf::Alias > aliases
 An array of aliases used for files within this external file. Aliases allow overriding inner file URIs.
int32_t bufferView = -1
 The index of the bufferView that contains the file data.
std::string mimeType = MimeType::model_gltf_json
std::optional< std::string > uri
 The URI (or IRI) of the external file.
std::string name
static constexpr const char * TypeName = "File"
Definition at line 19 of file File.h.
int64_t CesiumGltf::File::getSizeBytes ( ) const
Definition at line 74 of file File.h.
◆ aliases
std::vector<CesiumGltf::Alias> CesiumGltf::File::aliases
Definition at line 40 of file File.h.
◆ bufferView
int32_t CesiumGltf::File::bufferView = -1
This field MUST NOT be defined when uri is defined.
Definition at line 47 of file File.h.
◆ mimeType
std::string CesiumGltf::File::mimeType = MimeType::model_gltf_json
Known values are defined in MimeType.
This field is required and MUST always be defined.
Definition at line 57 of file File.h.
const char* CesiumGltf::File::TypeName = "File"
Definition at line 23 of file File.h.
◆ uri
std::optional<std::string> CesiumGltf::File::uri
Relative paths are relative to the current glTF asset. Instead of referencing an external file, this field MAY contain a data:-URI. This field MUST NOT be defined when bufferView is defined.
Definition at line 66 of file File.h.
