CesiumGltf::Alias Struct Referencefinal
Used to alias files referenced within an external file to other paths by the parent. More...
#include <CesiumGltf/Alias.h>
Inheritance diagram for CesiumGltf::Alias:
std::string alias
 String alias matched against an inner path.
int32_t file = -1
 The index of the file in the files array.
static constexpr const char * TypeName = "Alias"
Definition at line 16 of file Alias.h.
int64_t CesiumGltf::Alias::getSizeBytes ( ) const
Definition at line 38 of file Alias.h.
◆ alias
std::string CesiumGltf::Alias::alias
Definition at line 25 of file Alias.h.
◆ file
int32_t CesiumGltf::Alias::file = -1
Definition at line 30 of file Alias.h.
const char* CesiumGltf::Alias::TypeName = "Alias"
Definition at line 20 of file Alias.h.
