A texture containing feature IDs. More...
#include <CesiumGltf/FeatureIdTexture.h>
Public Member Functions inherited from CesiumGltf::TextureInfo | |
| std::vector< int64_t > | channels = {0} |
| Texture channels containing feature IDs, identified by index. Feature IDs may be packed into multiple channels if a single channel does not have sufficient bit depth to represent all feature ID values. The values are packed in little-endian order. | |
Public Attributes inherited from CesiumGltf::TextureInfo | |
| int32_t | index = -1 |
| The index of the texture. | |
| int64_t | texCoord = 0 |
| The set index of texture's TEXCOORD attribute used for texture coordinate mapping. | |
| static constexpr const char * | TypeName = "FeatureIdTexture" |
Static Public Attributes inherited from CesiumGltf::TextureInfo | |
| static constexpr const char * | TypeName = "TextureInfo" |
Definition at line 15 of file FeatureIdTexture.h.
Definition at line 35 of file FeatureIdTexture.h.
| std::vector<int64_t> CesiumGltf::FeatureIdTexture::channels = {0} |
Definition at line 27 of file FeatureIdTexture.h.
Definition at line 19 of file FeatureIdTexture.h.
