CesiumGltf::ExtensionMeshPrimitiveKhrMaterialsVariants Struct Referencefinal
KHR_materials_variants glTF Mesh Primitive Extension. More...
#include <CesiumGltf/ExtensionMeshPrimitiveKhrMaterialsVariants.h>
Inheritance diagram for CesiumGltf::ExtensionMeshPrimitiveKhrMaterialsVariants:
std::vector< CesiumGltf::ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValue > mappings
 A list of material to variant mappings.
static constexpr const char * ExtensionName = "KHR_materials_variants"
Definition at line 15 of file ExtensionMeshPrimitiveKhrMaterialsVariants.h.
int64_t CesiumGltf::ExtensionMeshPrimitiveKhrMaterialsVariants::getSizeBytes ( ) const
Definition at line 42 of file ExtensionMeshPrimitiveKhrMaterialsVariants.h.
◆ ExtensionName
const char* CesiumGltf::ExtensionMeshPrimitiveKhrMaterialsVariants::ExtensionName = "KHR_materials_variants"
Definition at line 24 of file ExtensionMeshPrimitiveKhrMaterialsVariants.h.
◆ mappings
std::vector< CesiumGltf::ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValue> CesiumGltf::ExtensionMeshPrimitiveKhrMaterialsVariants::mappings
An array of object values that associate an indexed material to a set of variants.
Definition at line 34 of file ExtensionMeshPrimitiveKhrMaterialsVariants.h.
const char* CesiumGltf::ExtensionMeshPrimitiveKhrMaterialsVariants::TypeName
Initial value:
"ExtensionMeshPrimitiveKhrMaterialsVariants"
Definition at line 20 of file ExtensionMeshPrimitiveKhrMaterialsVariants.h.
