CesiumGltf::ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValue Struct Referencefinal
ExtensionMeshPrimitiveKhrMaterialsVariants Mappings Value. More...
#include <CesiumGltf/ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValue.h>
Inheritance diagram for CesiumGltf::ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValue:
std::vector< int32_t > variants
 An array of variant index values.
int32_t material = -1
 The material associated with the set of variants.
 The user-defined name of this variant material mapping.
int64_t CesiumGltf::ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValue::getSizeBytes ( ) const
Definition at line 54 of file ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValue.h.
◆ material
int32_t CesiumGltf::ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValue::material = -1
A reference to the material associated with the given array of variants.
Definition at line 38 of file ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValue.h.
◆ name
std::optional<std::string> CesiumGltf::ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValue::name
The optional user-defined name of this variant material mapping. This is not necessarily unique.
Definition at line 46 of file ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValue.h.
const char* CesiumGltf::ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValue::TypeName
Initial value:
"ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValue"
Definition at line 22 of file ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValue.h.
◆ variants
std::vector<int32_t> CesiumGltf::ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValue::variants
An array of index values that reference variants defined in the glTF root's extension object.
Definition at line 31 of file ExtensionMeshPrimitiveKhrMaterialsVariantsMappingsValue.h.
