CesiumGltf::ExtensionExtVoxels Struct Referencefinal
EXT_voxels extension for a node in a glTF model to indicate voxel-based volumetric data More...
#include <CesiumGltf/ExtensionExtVoxels.h>
Inheritance diagram for CesiumGltf::ExtensionExtVoxels:
std::vector< int64_t > dimensions
 Dimensions of the voxel grid. The values are interpreted with respect to the shape indicated by shape.
std::optional< CesiumGltf::Padding > padding
 The optional padding of the voxels.
std::unordered_map< std::string, int32_t > attributes
 A plain JSON object, where each key corresponds to an attribute semantic and each value is the index of the accessor containing the attribute's data.
std::unordered_map< std::string, std::vector< double > > noData
 A plain JSON object, where each key corresponds to an existing semantic in attributes, and each value is the attribute's noData value. A noData value represents missing data—also known as a sentinel value—wherever it appears.
static constexpr const char * TypeName = "ExtensionExtVoxels"
static constexpr const char * ExtensionName = "EXT_voxels"
Definition at line 20 of file ExtensionExtVoxels.h.
int64_t CesiumGltf::ExtensionExtVoxels::getSizeBytes ( ) const
Definition at line 62 of file ExtensionExtVoxels.h.
◆ attributes
std::unordered_map<std::string, int32_t> CesiumGltf::ExtensionExtVoxels::attributes
Definition at line 46 of file ExtensionExtVoxels.h.
◆ dimensions
std::vector<int64_t> CesiumGltf::ExtensionExtVoxels::dimensions
Definition at line 34 of file ExtensionExtVoxels.h.
◆ ExtensionName
const char* CesiumGltf::ExtensionExtVoxels::ExtensionName = "EXT_voxels"
Definition at line 28 of file ExtensionExtVoxels.h.
◆ noData
std::unordered_map<std::string, std::vector<double> > CesiumGltf::ExtensionExtVoxels::noData
Definition at line 54 of file ExtensionExtVoxels.h.
◆ padding
std::optional<CesiumGltf::Padding> CesiumGltf::ExtensionExtVoxels::padding
Definition at line 39 of file ExtensionExtVoxels.h.
const char* CesiumGltf::ExtensionExtVoxels::TypeName = "ExtensionExtVoxels"
Definition at line 25 of file ExtensionExtVoxels.h.
