6#include <CesiumGltf/Padding.h>
12#include <unordered_map>
25 static constexpr const char*
TypeName =
"ExtensionExtVoxels";
39 std::optional<CesiumGltf::Padding>
padding;
54 std::unordered_map<std::string, std::vector<double>>
noData;
67 accum += int64_t(
sizeof(int64_t) * this->dimensions.capacity());
73 this->attributes.bucket_count() *
74 (
sizeof(std::string) +
sizeof(int32_t)));
75 for (
const auto& [k, v] : this->attributes) {
76 accum += int64_t(k.capacity() *
sizeof(
char) -
sizeof(std::string));
77 accum += int64_t(
sizeof(int32_t));
80 this->noData.bucket_count() *
81 (
sizeof(std::vector<double>)));
82 for (
const auto& [k, v] : this->noData) {
83 accum += int64_t(k.capacity() *
sizeof(
char) -
84 accum += int64_t(
sizeof(
double) * v.capacity());
EXT_voxels extension for a node in a glTF model to indicate voxel-based volumetric data
int64_t getSizeBytes() const
std::unordered_map< std::string, int32_t > attributes
A plain JSON object, where each key corresponds to an attribute semantic and each value is the index ...
std::unordered_map< std::string, std::vector< double > > noData
A plain JSON object, where each key corresponds to an existing semantic in attributes,...
std::vector< int64_t > dimensions
Dimensions of the voxel grid. The values are interpreted with respect to the shape indicated by shape...
std::optional< CesiumGltf::Padding > padding
The optional padding of the voxels.
The padding around a voxel grid. Specifies how many rows of attribute data come from neighboring grid...
