CesiumGltf::Padding Struct Referencefinal
The padding around a voxel grid. Specifies how many rows of attribute data come from neighboring grids in each dimension. More...
#include <CesiumGltf/Padding.h>
Inheritance diagram for CesiumGltf::Padding:
std::vector< int64_t > before
 before
std::vector< int64_t > after
 after
static constexpr const char * TypeName = "Padding"
Definition at line 16 of file Padding.h.
int64_t CesiumGltf::Padding::getSizeBytes ( ) const
Definition at line 38 of file Padding.h.
◆ after
std::vector<int64_t> CesiumGltf::Padding::after
after
Definition at line 30 of file Padding.h.
◆ before
std::vector<int64_t> CesiumGltf::Padding::before
before
Definition at line 25 of file Padding.h.
const char* CesiumGltf::Padding::TypeName = "Padding"
Definition at line 20 of file Padding.h.
