CesiumGltf::ExtensionExtPrimitiveVoxelsSpec Struct Reference
EXT_primitive_voxels extension for a primitive in a glTF model to indicate voxel-based volumetric data More...
#include <CesiumGltf/ExtensionExtPrimitiveVoxelsSpec.h>
Inheritance diagram for CesiumGltf::ExtensionExtPrimitiveVoxelsSpec:
CesiumUtility::ExtensibleObject CesiumGltf::ExtensionExtPrimitiveVoxels
int32_t shape = -1
 The index of the shape in KHR_implicit_shapes that the voxel grid adheres to.
std::vector< int64_t > dimensions
 Dimensions of the voxel grid. The values are interpreted with respect to the shape indicated by KHR_implicit_shapes.
std::optional< CesiumGltf::Padding > padding
 The optional padding of the voxels.
std::unordered_map< std::string, std::vector< double > > noData
 A plain JSON object, where each key corresponds to an existing semantic in the primitive's attributes, and each value is the attribute's noData value. A noData value represents missing data — also known as a sentinel value — wherever it appears.
static constexpr const char * TypeName = "ExtensionExtPrimitiveVoxels"
static constexpr const char * ExtensionName = "EXT_primitive_voxels"
Protected Member Functions
 ExtensionExtPrimitiveVoxelsSpec ()=default
 This class is not meant to be instantiated directly. Use ExtensionExtPrimitiveVoxels instead.
Friends
struct ExtensionExtPrimitiveVoxels
Definition at line 20 of file ExtensionExtPrimitiveVoxelsSpec.h.
int64_t CesiumGltf::ExtensionExtPrimitiveVoxelsSpec::getSizeBytes ( ) const
Definition at line 61 of file ExtensionExtPrimitiveVoxelsSpec.h.
◆ ExtensionExtPrimitiveVoxels
friend struct ExtensionExtPrimitiveVoxels
friend
Definition at line 87 of file ExtensionExtPrimitiveVoxelsSpec.h.
◆ dimensions
std::vector<int64_t> CesiumGltf::ExtensionExtPrimitiveVoxelsSpec::dimensions
Definition at line 40 of file ExtensionExtPrimitiveVoxelsSpec.h.
◆ ExtensionName
const char* CesiumGltf::ExtensionExtPrimitiveVoxelsSpec::ExtensionName = "EXT_primitive_voxels"
Definition at line 28 of file ExtensionExtPrimitiveVoxelsSpec.h.
◆ noData
std::unordered_map<std::string, std::vector<double> > CesiumGltf::ExtensionExtPrimitiveVoxelsSpec::noData
Definition at line 53 of file ExtensionExtPrimitiveVoxelsSpec.h.
◆ padding
std::optional<CesiumGltf::Padding> CesiumGltf::ExtensionExtPrimitiveVoxelsSpec::padding
Definition at line 45 of file ExtensionExtPrimitiveVoxelsSpec.h.
◆ shape
int32_t CesiumGltf::ExtensionExtPrimitiveVoxelsSpec::shape = -1
Definition at line 34 of file ExtensionExtPrimitiveVoxelsSpec.h.
const char* CesiumGltf::ExtensionExtPrimitiveVoxelsSpec::TypeName = "ExtensionExtPrimitiveVoxels"
Definition at line 25 of file ExtensionExtPrimitiveVoxelsSpec.h.
