CesiumGltf::ExtensionExtPrimitiveVoxels Struct Referencefinal
This class is not meant to be instantiated directly. Use ExtensionExtPrimitiveVoxels instead. More...
#include <CesiumGltf/ExtensionExtPrimitiveVoxels.h>
Inheritance diagram for CesiumGltf::ExtensionExtPrimitiveVoxels:
CesiumGltf::ExtensionExtPrimitiveVoxelsSpec CesiumUtility::ExtensibleObject
static constexpr int32_t MODE = 2147483647
 The constant used to indicate a voxel primitive in CesiumGltf::MeshPrimitive::mode.
- Static Public Attributes inherited from CesiumGltf::ExtensionExtPrimitiveVoxelsSpec
static constexpr const char * TypeName = "ExtensionExtPrimitiveVoxels"
static constexpr const char * ExtensionName = "EXT_primitive_voxels"
Additional Inherited Members
- Public Member Functions inherited from CesiumGltf::ExtensionExtPrimitiveVoxelsSpec
- Public Attributes inherited from CesiumGltf::ExtensionExtPrimitiveVoxelsSpec
int32_t shape = -1
 The index of the shape in KHR_implicit_shapes that the voxel grid adheres to.
std::vector< int64_t > dimensions
 Dimensions of the voxel grid. The values are interpreted with respect to the shape indicated by KHR_implicit_shapes.
std::optional< CesiumGltf::Padding > padding
 The optional padding of the voxels.
std::unordered_map< std::string, std::vector< double > > noData
 A plain JSON object, where each key corresponds to an existing semantic in the primitive's attributes, and each value is the attribute's noData value. A noData value represents missing data — also known as a sentinel value — wherever it appears.
- Protected Member Functions inherited from CesiumGltf::ExtensionExtPrimitiveVoxelsSpec
 ExtensionExtPrimitiveVoxelsSpec ()=default
Definition at line 8 of file ExtensionExtPrimitiveVoxels.h.
◆ MODE
int32_t CesiumGltf::ExtensionExtPrimitiveVoxels::MODE = 2147483647
Definition at line 14 of file ExtensionExtPrimitiveVoxels.h.
