CesiumGltf::ExtensionExtInstanceFeatures Struct Referencefinal
An object describing per-instance feature IDs. More...
#include <CesiumGltf/ExtensionExtInstanceFeatures.h>
Inheritance diagram for CesiumGltf::ExtensionExtInstanceFeatures:
std::vector< CesiumGltf::ExtensionExtInstanceFeaturesFeatureId > featureIds
 An array of feature ID sets.
static constexpr const char * TypeName = "ExtensionExtInstanceFeatures"
static constexpr const char * ExtensionName = "EXT_instance_features"
Definition at line 15 of file ExtensionExtInstanceFeatures.h.
int64_t CesiumGltf::ExtensionExtInstanceFeatures::getSizeBytes ( ) const
Definition at line 36 of file ExtensionExtInstanceFeatures.h.
◆ ExtensionName
const char* CesiumGltf::ExtensionExtInstanceFeatures::ExtensionName = "EXT_instance_features"
Definition at line 23 of file ExtensionExtInstanceFeatures.h.
◆ featureIds
std::vector<CesiumGltf::ExtensionExtInstanceFeaturesFeatureId> CesiumGltf::ExtensionExtInstanceFeatures::featureIds
Definition at line 28 of file ExtensionExtInstanceFeatures.h.
const char* CesiumGltf::ExtensionExtInstanceFeatures::TypeName = "ExtensionExtInstanceFeatures"
Definition at line 20 of file ExtensionExtInstanceFeatures.h.
