ExtensionExtInstanceFeatures.h
5#include <CesiumGltf/ExtensionExtInstanceFeaturesFeatureId.h>
9#include <vector>
10
11namespace CesiumGltf {
15struct CESIUMGLTF_API ExtensionExtInstanceFeatures final
20 static constexpr const char* TypeName = "ExtensionExtInstanceFeatures";
23 static constexpr const char* ExtensionName = "EXT_instance_features";
24
28 std::vector<CesiumGltf::ExtensionExtInstanceFeaturesFeatureId> featureIds;
29
36 int64_t getSizeBytes() const {
37 int64_t accum = 0;
38 accum += int64_t(sizeof(ExtensionExtInstanceFeatures));
40 int64_t(sizeof(CesiumUtility::ExtensibleObject));
41 accum += int64_t(
43 this->featureIds.capacity());
45 this->featureIds) {
46 accum +=
47 value.getSizeBytes() -
49 }
50 return accum;
51 }
52};
53} // namespace CesiumGltf
Feature IDs stored in a GPU mesh instancing attribute.
An object describing per-instance feature IDs.
std::vector< CesiumGltf::ExtensionExtInstanceFeaturesFeatureId > featureIds
An array of feature ID sets.
