CesiumGltf::ExtensionExtInstanceFeaturesFeatureId Struct Referencefinal
Feature IDs stored in a GPU mesh instancing attribute. More...
#include <CesiumGltf/ExtensionExtInstanceFeaturesFeatureId.h>
Inheritance diagram for CesiumGltf::ExtensionExtInstanceFeaturesFeatureId:
int64_t featureCount = int64_t()
 The number of unique features in the attribute.
std::optional< int64_t > nullFeatureId
 A value that indicates that no feature is associated with this instance.
std::optional< std::string > label
 A label assigned to this feature ID set. Labels must be alphanumeric identifiers matching the regular expression ^[a-zA-Z_][a-zA-Z0-9_]*$.
std::optional< int64_t > attribute
 An integer value used to construct a string in the format _FEATURE_ID_<set index> which is a reference to a key in EXT_mesh_gpu_instancing.attributes dictionary (e.g. a value of 0 corresponds to _FEATURE_ID_0).
std::optional< int64_t > propertyTable
 The index of the property table containing per-feature property values. Only applicable when using the EXT_structural_metadata extension.
Definition at line 16 of file ExtensionExtInstanceFeaturesFeatureId.h.
int64_t CesiumGltf::ExtensionExtInstanceFeaturesFeatureId::getSizeBytes ( ) const
Definition at line 61 of file ExtensionExtInstanceFeaturesFeatureId.h.
◆ attribute
std::optional<int64_t> CesiumGltf::ExtensionExtInstanceFeaturesFeatureId::attribute
Definition at line 47 of file ExtensionExtInstanceFeaturesFeatureId.h.
◆ featureCount
int64_t CesiumGltf::ExtensionExtInstanceFeaturesFeatureId::featureCount = int64_t()
Definition at line 27 of file ExtensionExtInstanceFeaturesFeatureId.h.
◆ label
std::optional<std::string> CesiumGltf::ExtensionExtInstanceFeaturesFeatureId::label
Definition at line 39 of file ExtensionExtInstanceFeaturesFeatureId.h.
◆ nullFeatureId
std::optional<int64_t> CesiumGltf::ExtensionExtInstanceFeaturesFeatureId::nullFeatureId
Definition at line 33 of file ExtensionExtInstanceFeaturesFeatureId.h.
◆ propertyTable
std::optional<int64_t> CesiumGltf::ExtensionExtInstanceFeaturesFeatureId::propertyTable
Definition at line 53 of file ExtensionExtInstanceFeaturesFeatureId.h.
const char* CesiumGltf::ExtensionExtInstanceFeaturesFeatureId::TypeName
Initial value:
"ExtensionExtInstanceFeaturesFeatureId"
Definition at line 21 of file ExtensionExtInstanceFeaturesFeatureId.h.
