CesiumGltf::Extension3dTilesTilesetVoxels Struct Referencefinal
3D Tiles voxel content extension. Indicates the presence of voxel content and associates it with metadata definitions in the tileset's schema. More...
#include <CesiumGltf/Extension3dTilesTilesetVoxels.h>
Inheritance diagram for CesiumGltf::Extension3dTilesTilesetVoxels:
std::vector< int64_t > dimensions
 Dimensions of the voxel grid.
std::optional< CesiumGltf::Padding > padding
 The optional padding of the voxels.
std::string classProperty
 The class that property values conform to. The value shall be a class ID declared in the classes dictionary.
static constexpr const char * TypeName = "Extension3dTilesTilesetVoxels"
static constexpr const char * ExtensionName = "3DTILES_tileset_voxels"
Definition at line 19 of file Extension3dTilesTilesetVoxels.h.
int64_t CesiumGltf::Extension3dTilesTilesetVoxels::getSizeBytes ( ) const
Definition at line 51 of file Extension3dTilesTilesetVoxels.h.
◆ classProperty
std::string CesiumGltf::Extension3dTilesTilesetVoxels::classProperty
Definition at line 43 of file Extension3dTilesTilesetVoxels.h.
◆ dimensions
std::vector<int64_t> CesiumGltf::Extension3dTilesTilesetVoxels::dimensions
Definition at line 32 of file Extension3dTilesTilesetVoxels.h.
◆ ExtensionName
const char* CesiumGltf::Extension3dTilesTilesetVoxels::ExtensionName = "3DTILES_tileset_voxels"
Definition at line 27 of file Extension3dTilesTilesetVoxels.h.
◆ padding
std::optional<CesiumGltf::Padding> CesiumGltf::Extension3dTilesTilesetVoxels::padding
Definition at line 37 of file Extension3dTilesTilesetVoxels.h.
const char* CesiumGltf::Extension3dTilesTilesetVoxels::TypeName = "Extension3dTilesTilesetVoxels"
Definition at line 24 of file Extension3dTilesTilesetVoxels.h.
