Extension3dTilesTilesetVoxels.h
6#include <CesiumGltf/Padding.h>
9#include <cstdint>
10#include <optional>
11#include <string>
12#include <vector>
13
14namespace CesiumGltf {
19struct CESIUMGLTF_API Extension3dTilesTilesetVoxels final
24 static constexpr const char* TypeName = "Extension3dTilesTilesetVoxels";
27 static constexpr const char* ExtensionName = "3DTILES_tileset_voxels";
28
32 std::vector<int64_t> dimensions;
33
37 std::optional<CesiumGltf::Padding> padding;
38
43 std::string classProperty;
44
51 int64_t getSizeBytes() const {
52 int64_t accum = 0;
53 accum += int64_t(sizeof(Extension3dTilesTilesetVoxels));
55 int64_t(sizeof(CesiumUtility::ExtensibleObject));
56 accum += int64_t(sizeof(int64_t) * this->dimensions.capacity());
57 if (this->padding) {
58 accum +=
59 this->padding->getSizeBytes() - int64_t(sizeof(CesiumGltf::Padding));
60 }
61 accum += int64_t(this->classProperty.capacity() * sizeof(char));
62 return accum;
63 }
64};
65} // namespace CesiumGltf
3D Tiles voxel content extension. Indicates the presence of voxel content and associates it with meta...
The class that property values conform to. The value shall be a class ID declared in the classes dict...
std::optional< CesiumGltf::Padding > padding
The optional padding of the voxels.
std::vector< int64_t > dimensions
Dimensions of the voxel grid.
The padding around a voxel grid. Specifies how many rows of attribute data come from neighboring grid...
Definition Padding.h:16
