CesiumGltf::ColorFromAccessor Struct Reference
Visitor that retrieves the color from the given accessor type as a glm::dvec4. More...
#include <CesiumGltf/AccessorUtility.h>
std::optional< glm::dvec4 > operator() (const AccessorView< AccessorTypes::VEC3< T > > &value)
 Attempts to obtain a glm::dvec4 at the given index from an accessor over a vec3. The values will be cast to double and, if applicable, normalized based on std::numeric_limits<T>::max(). The fourth component will be set to 1.0. If the index is invalid, std::nullopt is returned instead.
std::optional< glm::dvec4 > operator() (const AccessorView< AccessorTypes::VEC4< T > > &value)
 Attempts to obtain a glm::dvec4 at the given index from an accessor over a vec4. The values will be cast to double and, if applicable, normalized based on std::numeric_limits<T>::max(). If the index is invalid, std::nullopt is returned instead.
int64_t index
 The index of the color to obtain.
Definition at line 656 of file AccessorUtility.h.
◆ operator()() [1/2]
std::optional< glm::dvec4 > CesiumGltf::ColorFromAccessor::operator() ( const AccessorView< AccessorTypes::VEC3< T > > & value)
Definition at line 666 of file AccessorUtility.h.
◆ operator()() [2/2]
std::optional< glm::dvec4 > CesiumGltf::ColorFromAccessor::operator() ( const AccessorView< AccessorTypes::VEC4< T > > & value)
Definition at line 694 of file AccessorUtility.h.
◆ index
int64_t CesiumGltf::ColorFromAccessor::index
Definition at line 715 of file AccessorUtility.h.
