A buffer points to binary geometry, animation, or skins. More...
#include <CesiumGltf/BufferSpec.h>
Public Member Functions inherited from CesiumGltf::NamedObject | |
| Calculates the size in bytes of this object, including the contents of all collections, pointers, and strings. Calling this method may be slow as it requires traversing the object's entire structure. | |
| int32_t | chunk = -1 |
| The index of the chunk that contains the buffer data. | |
| std::optional< std::string > | uri |
| The URI (or IRI) of the buffer. | |
| int64_t | byteLength = int64_t() |
| The length of the buffer in bytes. | |
Public Attributes inherited from CesiumGltf::NamedObject | |
| std::string | name |
| The user-defined name of this object. | |
| static constexpr const char * | TypeName = "Buffer" |
| BufferSpec ()=default | |
| This class is not meant to be instantiated directly. Use Buffer instead. | |
Friends | |
| struct | Buffer |
Definition at line 16 of file BufferSpec.h.
Definition at line 50 of file BufferSpec.h.
friend |
Definition at line 67 of file BufferSpec.h.
| int64_t CesiumGltf::BufferSpec::byteLength = int64_t() |
Definition at line 42 of file BufferSpec.h.
| int32_t CesiumGltf::BufferSpec::chunk = -1 |
If neither chunk nor uri is defined on buffer 0, then buffer 0 implicitly refers to chunk 1. There is no default chunk index for other buffers.
Definition at line 29 of file BufferSpec.h.
Definition at line 20 of file BufferSpec.h.
| std::optional<std::string> CesiumGltf::BufferSpec::uri |
Relative paths are relative to the current glTF asset. Instead of referencing an external file, this field MAY contain a data:-URI.
Definition at line 37 of file BufferSpec.h.
