CesiumGltf::AnimationChannelTarget Struct Referencefinal
The descriptor of the animated property. More...
#include <CesiumGltf/AnimationChannelTarget.h>
Inheritance diagram for CesiumGltf::AnimationChannelTarget:
Classes
struct  Path
 Known values for The name of the node's TRS property to animate, or the "weights" of the Morph Targets it instantiates. For the "translation" property, the values that are provided by the sampler are the translation along the X, Y, and Z axes. For the "rotation" property, the values are a quaternion in the order (x, y, z, w), where w is the scalar. For the "scale" property, the values are the scaling factors along the X, Y, and Z axes. More...
int32_t node = -1
 The index of the node to animate. When undefined, the animated object MAY be defined by an extension.
std::string path = Path::translation
static constexpr const char * TypeName = "AnimationChannelTarget"
Definition at line 15 of file AnimationChannelTarget.h.
int64_t CesiumGltf::AnimationChannelTarget::getSizeBytes ( ) const
Definition at line 70 of file AnimationChannelTarget.h.
◆ node
int32_t CesiumGltf::AnimationChannelTarget::node = -1
Definition at line 49 of file AnimationChannelTarget.h.
◆ path
std::string CesiumGltf::AnimationChannelTarget::path = Path::translation
Known values are defined in Path.
Definition at line 62 of file AnimationChannelTarget.h.
const char* CesiumGltf::AnimationChannelTarget::TypeName = "AnimationChannelTarget"
Definition at line 20 of file AnimationChannelTarget.h.
