CesiumGltf::AnimationChannelTarget::Path Struct Reference
Known values for The name of the node's TRS property to animate, or the "weights" of the Morph Targets it instantiates. For the "translation" property, the values that are provided by the sampler are the translation along the X, Y, and Z axes. For the "rotation" property, the values are a quaternion in the order (x, y, z, w), where w is the scalar. For the "scale" property, the values are the scaling factors along the X, Y, and Z axes. More...
#include <CesiumGltf/AnimationChannelTarget.h>
static const std::string translation = "translation"
 translation
static const std::string rotation = "rotation"
 rotation
static const std::string scale = "scale"
 scale
static const std::string weights = "weights"
 weights
Definition at line 31 of file AnimationChannelTarget.h.
◆ rotation
const std::string CesiumGltf::AnimationChannelTarget::Path::rotation = "rotation"
inlinestatic
rotation
Definition at line 36 of file AnimationChannelTarget.h.
◆ scale
const std::string CesiumGltf::AnimationChannelTarget::Path::scale = "scale"
inlinestatic
scale
Definition at line 39 of file AnimationChannelTarget.h.
◆ translation
const std::string CesiumGltf::AnimationChannelTarget::Path::translation = "translation"
inlinestatic
translation
Definition at line 33 of file AnimationChannelTarget.h.
◆ weights
const std::string CesiumGltf::AnimationChannelTarget::Path::weights = "weights"
inlinestatic
weights
Definition at line 42 of file AnimationChannelTarget.h.
