AnimationChannelTarget.h
8#include <cstdint>
9#include <string>
10
11namespace CesiumGltf {
15struct CESIUMGLTF_API AnimationChannelTarget final
20 static constexpr const char* TypeName = "AnimationChannelTarget";
21
31 struct Path {
33 inline static const std::string translation = "translation";
34
36 inline static const std::string rotation = "rotation";
37
39 inline static const std::string scale = "scale";
40
42 inline static const std::string weights = "weights";
43 };
44
49 int32_t node = -1;
50
62 std::string path = Path::translation;
63
70 int64_t getSizeBytes() const {
71 int64_t accum = 0;
72 accum += int64_t(sizeof(AnimationChannelTarget));
74 int64_t(sizeof(CesiumUtility::ExtensibleObject));
75
76 return accum;
77 }
78};
79} // namespace CesiumGltf
Known values for The name of the node's TRS property to animate, or the "weights" of the Morph Target...
translation
rotation
The descriptor of the animated property.
std::string path
The name of the node's TRS property to animate, or the "weights" of the Morph Targets it instantiates...
int32_t node
The index of the node to animate. When undefined, the animated object MAY be defined by an extension.
