An object pointing to a buffer view containing the deviating accessor values. The number of elements is equal to accessor.sparse.count times number of components. The elements have the same component type as the base accessor. The elements are tightly packed. Data MUST be aligned following the same rules as the base accessor.
More...
#include <CesiumGltf/AccessorSparseValues.h>
| int32_t | bufferView = -1 |
The index of the bufferView with sparse values. The referenced buffer view MUST NOT have its target or byteStride properties defined. | |
| int64_t | byteOffset = 0 |
| The offset relative to the start of the bufferView in bytes. | |
| static constexpr const char * | TypeName = "AccessorSparseValues" |
Definition at line 18 of file AccessorSparseValues.h.
Definition at line 43 of file AccessorSparseValues.h.
| int32_t CesiumGltf::AccessorSparseValues::bufferView = -1 |
Definition at line 30 of file AccessorSparseValues.h.
| int64_t CesiumGltf::AccessorSparseValues::byteOffset = 0 |
Definition at line 35 of file AccessorSparseValues.h.
Definition at line 23 of file AccessorSparseValues.h.
