An object pointing to a buffer view containing the indices of deviating accessor values. The number of indices is equal to accessor.sparse.count. Indices MUST strictly increase.
More...
#include <CesiumGltf/AccessorSparseIndices.h>
Classes | |
| struct | ComponentType |
| Known values for The indices data type. More... | |
| int32_t | bufferView = -1 |
The index of the buffer view with sparse indices. The referenced buffer view MUST NOT have its target or byteStride properties defined. The buffer view and the optional byteOffset MUST be aligned to the componentType byte length. | |
| int64_t | byteOffset = 0 |
| The offset relative to the start of the buffer view in bytes. | |
| int32_t | componentType = ComponentType::UNSIGNED_BYTE |
| The indices data type. | |
| static constexpr const char * | TypeName = "AccessorSparseIndices" |
Definition at line 16 of file AccessorSparseIndices.h.
Definition at line 64 of file AccessorSparseIndices.h.
| int32_t CesiumGltf::AccessorSparseIndices::bufferView = -1 |
Definition at line 43 of file AccessorSparseIndices.h.
| int64_t CesiumGltf::AccessorSparseIndices::byteOffset = 0 |
Definition at line 48 of file AccessorSparseIndices.h.
| int32_t CesiumGltf::AccessorSparseIndices::componentType = ComponentType::UNSIGNED_BYTE |
Known values are defined in ComponentType.
Definition at line 56 of file AccessorSparseIndices.h.
Definition at line 21 of file AccessorSparseIndices.h.
