Cesium3DTilesSelection::GltfModifierInput Struct Reference
The input to GltfModifier::apply. More...
#include <Cesium3DTilesSelection/GltfModifier.h>
int64_t version
 The version of the GltfModifier, as returned by GltfModifier::getCurrentVersion at the start of the modification.
CesiumAsync::AsyncSystem asyncSystem
 The async system that can be used to do work in threads.
std::shared_ptr< CesiumAsync::IAssetAccessor > pAssetAccessor
 An asset accessor that can be used to obtain additional assets.
std::shared_ptr< spdlog::logger > pLogger
 The logger.
const CesiumGltf::Model & previousModel
 The model to be modified.
glm::dmat4 tileTransform
 The transformation of the model's coordinates to the tileset's coordinate system.
Definition at line 29 of file GltfModifier.h.
◆ asyncSystem
CesiumAsync::AsyncSystem Cesium3DTilesSelection::GltfModifierInput::asyncSystem
Definition at line 43 of file GltfModifier.h.
◆ pAssetAccessor
std::shared_ptr<CesiumAsync::IAssetAccessor> Cesium3DTilesSelection::GltfModifierInput::pAssetAccessor
Definition at line 48 of file GltfModifier.h.
◆ pLogger
std::shared_ptr<spdlog::logger> Cesium3DTilesSelection::GltfModifierInput::pLogger
The logger.
Definition at line 53 of file GltfModifier.h.
◆ previousModel
const CesiumGltf::Model& Cesium3DTilesSelection::GltfModifierInput::previousModel
Definition at line 58 of file GltfModifier.h.
◆ tileTransform
glm::dmat4 Cesium3DTilesSelection::GltfModifierInput::tileTransform
Definition at line 64 of file GltfModifier.h.
◆ version
int64_t Cesium3DTilesSelection::GltfModifierInput::version
This is provided because calling GltfModifier::getCurrentVersion may return a newer version if GltfModifier::trigger is called again while GltfModifier::apply is running in a worker thread.
Definition at line 38 of file GltfModifier.h.
