CesiumJsonReader::SharedAssetJsonHandler Class Reference
IJsonHandler for SharedAsset values. More...
#include <CesiumJsonReader/SharedAssetJsonHandler.h>
Inheritance diagram for CesiumJsonReader::SharedAssetJsonHandler:
CesiumJsonReader::ExtensibleObjectJsonHandler CesiumJsonReader::ObjectJsonHandler CesiumJsonReader::JsonHandler CesiumJsonReader::IJsonHandler
 SharedAssetJsonHandler (const CesiumJsonReader::JsonReaderOptions &context) noexcept
 Creates an SharedAssetJsonHandler with the specified options.
- Public Member Functions inherited from CesiumJsonReader::ExtensibleObjectJsonHandler
 ExtensibleObjectJsonHandler (const JsonReaderOptions &context) noexcept
 Creates an ExtensibleObjectJsonHandler with the specified options.
- Public Member Functions inherited from CesiumJsonReader::ObjectJsonHandler
virtual IJsonHandler * readObjectEnd () override
- Public Member Functions inherited from CesiumJsonReader::JsonHandler
virtual IJsonHandler * readObjectKey (const std::string_view &str) override
Protected Member Functions
void reset (IJsonHandler *pParent, CesiumUtility::ExtensibleObject *pObject)
 Resets the current parent of this handler, and the current object being handled.
IJsonHandler * readObjectKeySharedAsset (const std::string &objectType, const std::string_view &str, CesiumUtility::ExtensibleObject &o)
 Reads a property of an ExtensibleObject from the JSON.
- Protected Member Functions inherited from CesiumJsonReader::ExtensibleObjectJsonHandler
IJsonHandler * readObjectKeyExtensibleObject (const std::string &objectType, const std::string_view &str, CesiumUtility::ExtensibleObject &o)
- Protected Member Functions inherited from CesiumJsonReader::ObjectJsonHandler
virtual IJsonHandler * StartSubObject () noexcept
 Called when readObjectStart is called when the depth of the ObjectJsonHandler is greater than 0.
virtual IJsonHandler * EndSubObject () noexcept
 Called when readObjectEnd is called when the depth of the ObjectJsonHandler is greater than 0.
template<typename TAccessor, typename TProperty>
IJsonHandler * property (const char *currentKey, TAccessor &accessor, TProperty &value)
 Called from IJsonHandler::readObjectKey to read a property into an object.
const char * getCurrentKey () const noexcept
 Obtains the most recent key handled by this JsonHandler.
void setCurrentKey (const char *key) noexcept
 Sets the most recent key handled by this JsonHandler.
- Protected Member Functions inherited from CesiumJsonReader::JsonHandler
IJsonHandler * parent ()
IJsonHandler * ignoreAndReturnToParent ()
IJsonHandler * ignoreAndContinue ()
This is more or less the same as directly using ExtensibleObjectJsonHandler, and exists for compatibility with generated code.
Definition at line 19 of file SharedAssetJsonHandler.h.
◆ SharedAssetJsonHandler()
CesiumJsonReader::SharedAssetJsonHandler::SharedAssetJsonHandler ( const CesiumJsonReader::JsonReaderOptions & context)
explicitnoexcept
contextOptions to configure how the JSON is parsed.
◆ readObjectKeySharedAsset()
IJsonHandler * CesiumJsonReader::SharedAssetJsonHandler::readObjectKeySharedAsset ( const std::string & objectType,
const std::string_view & str,
CesiumUtility::ExtensibleObject & o )
protected
objectTypeThe name of the ExtensibleObject's type.
strThe object key being read.
oThe ExtensibleObject we're currently reading into.
◆ reset()
void CesiumJsonReader::SharedAssetJsonHandler::reset ( IJsonHandler * pParent,
CesiumUtility::ExtensibleObject * pObject )
protected
