Contains assets that are potentially shared across multiple glTF models. More...
#include <CesiumGltfReader/GltfSharedAssetSystem.h>
Public Types | |
| using | ImageDepot |
| A depot containing images loaded from glTFs. | |
| using | SchemaDepot |
| A depot containing schemas loaded from URIs contained in the glTF EXT_structural_metadata extension. | |
| static CesiumUtility::IntrusivePointer< GltfSharedAssetSystem > | getDefault () |
Obtains an IntrusivePointer to the GltfSharedAssetSystem singleton. | |
| CesiumUtility::IntrusivePointer< ImageDepot > | pImage |
| The asset depot for images. | |
| CesiumUtility::IntrusivePointer< SchemaDepot > | pExternalMetadataSchema |
| The asset depot for schemas. | |
Public Member Functions inherited from CesiumUtility::ReferenceCounted< T, true > | |
Definition at line 17 of file GltfSharedAssetSystem.h.
See ImageAsset and NetworkImageAssetDescriptor.
Definition at line 34 of file GltfSharedAssetSystem.h.
See Schema and NetworkSchemaAssetDescriptor.
Definition at line 48 of file GltfSharedAssetSystem.h.
| CesiumUtility::IntrusivePointer<SchemaDepot> CesiumGltfReader::GltfSharedAssetSystem::pExternalMetadataSchema |
Definition at line 54 of file GltfSharedAssetSystem.h.
| CesiumUtility::IntrusivePointer<ImageDepot> CesiumGltfReader::GltfSharedAssetSystem::pImage |
Definition at line 40 of file GltfSharedAssetSystem.h.
