CesiumGltfReader::GltfReader Class Reference
Reads glTF models and images. More...
#include <CesiumGltfReader/GltfReader.h>
 GltfReader ()
const CesiumJsonReader::JsonReaderOptions & getExtensions () const
GltfReaderResult readGltf (const std::span< const std::byte > &data, const GltfReaderOptions &options=GltfReaderOptions()) const
 Reads a glTF or binary glTF (GLB) from a buffer.
CesiumAsync::Future< GltfReaderResult > readGltfAndExternalData (const std::span< const std::byte > &data, const CesiumAsync::AsyncSystem &asyncSystem, const CesiumAsync::HttpHeaders &headers, const std::shared_ptr< CesiumAsync::IAssetAccessor > &pAssetAccessor, const std::string &baseUrl={}, const GltfReaderOptions &options=GltfReaderOptions()) const
 Read a glTF or binary glTF (GLB) from a buffer and then resolve external references.
CesiumAsync::Future< GltfReaderResult > readGltfAndExternalData (const std::span< const std::byte > &data, const CesiumAsync::AsyncSystem &asyncSystem, const std::vector< CesiumAsync::IAssetAccessor::THeader > &headers, const std::shared_ptr< CesiumAsync::IAssetAccessor > &pAssetAccessor, const std::string &baseUrl={}, const GltfReaderOptions &options=GltfReaderOptions()) const
CesiumAsync::Future< GltfReaderResult > loadGltf (const CesiumAsync::AsyncSystem &asyncSystem, const std::string &url, const std::vector< CesiumAsync::IAssetAccessor::THeader > &headers, const std::shared_ptr< CesiumAsync::IAssetAccessor > &pAssetAccessor, const GltfReaderOptions &options=GltfReaderOptions()) const
 Reads a glTF or binary glTF file from a URL and resolves external buffers and images.
void postprocessGltf (GltfReaderResult &readGltf, const GltfReaderOptions &options)
 Performs post-load processing on a glTF. The specific operations performed are controlled by the provided options.
static CesiumAsync::Future< GltfReaderResult > resolveExternalData (const CesiumAsync::AsyncSystem &asyncSystem, const std::string &baseUrl, const CesiumAsync::HttpHeaders &headers, const std::shared_ptr< CesiumAsync::IAssetAccessor > &pAssetAccessor, const GltfReaderOptions &options, GltfReaderResult &&result)
 Accepts the result of readGltf and resolves any remaining external buffers and images.
static CesiumImage::ImageReaderResult readImage (const std::span< const std::byte > &data, const CesiumImage::Ktx2TranscodeTargets &ktx2TranscodeTargets)
 Reads an Image from a buffer.
static std::optional< std::string > generateMipMaps (CesiumImage::ImageAsset &image)
 Generate mipmaps for this image.
Definition at line 170 of file GltfReader.h.
◆ generateMipMaps()
static std::optional< std::string > CesiumGltfReader::GltfReader::generateMipMaps ( CesiumImage::ImageAsset & image)
static
Deprecated
Use CesiumImage::ImageDecoder::generateMipMaps instead.
◆ loadGltf()
CesiumAsync::Future< GltfReaderResult > CesiumGltfReader::GltfReader::loadGltf ( const CesiumAsync::AsyncSystem & asyncSystem,
const std::string & url,
const std::vector< CesiumAsync::IAssetAccessor::THeader > & headers,
const std::shared_ptr< CesiumAsync::IAssetAccessor > & pAssetAccessor,
const GltfReaderOptions & options = GltfReaderOptions() ) const
asyncSystemThe async system to use for resolving external data.
urlThe url for reading the file.
headershttp headers needed to make the request.
pAssetAccessorThe asset accessor to use to make the necessary requests.
optionsOptions for how to read the glTF.
◆ postprocessGltf()
void CesiumGltfReader::GltfReader::postprocessGltf ( GltfReaderResult & readGltf,
const GltfReaderOptions & options )
readGltfThe result of reading the glTF.
optionsThe options to use in post-processing.
◆ readGltf()
GltfReaderResult CesiumGltfReader::GltfReader::readGltf ( const std::span< const std::byte > & data,
dataThe buffer from which to read the glTF.
◆ readGltfAndExternalData() [1/2]
CesiumAsync::Future< GltfReaderResult > CesiumGltfReader::GltfReader::readGltfAndExternalData ( const std::span< const std::byte > & data,
const CesiumAsync::HttpHeaders & headers,
const std::string & baseUrl = {},
dataThe data bytes of the glTF file
baseUrlThe url to which all external urls are relative
◆ readGltfAndExternalData() [2/2]
◆ readImage()
static CesiumImage::ImageReaderResult CesiumGltfReader::GltfReader::readImage ( const std::span< const std::byte > & data,
const CesiumImage::Ktx2TranscodeTargets & ktx2TranscodeTargets )
static
Deprecated
Use CesiumImage::ImageDecoder::readImage instead.
◆ resolveExternalData()
static CesiumAsync::Future< GltfReaderResult > CesiumGltfReader::GltfReader::resolveExternalData ( const CesiumAsync::AsyncSystem & asyncSystem,
const std::string & baseUrl,
const GltfReaderOptions & options,
GltfReaderResult && result )
static
baseUrlThe base url that all the external uris are relative to.
headersThe http headers needed to make any external data requests.
pAssetAccessorThe asset accessor to use to request the external buffers and images.
resultThe result of the synchronous readGltf invocation.
