cesium-native 0.61.0
CesiumGltfReader::ImageDecoder Class Reference
Contains methods for reading and manipulating images. More...
#include <CesiumGltfReader/ImageDecoder.h>
static ImageReaderResult readImage (const std::span< const std::byte > &data, const CesiumGltf::Ktx2TranscodeTargets &ktx2TranscodeTargets)
 Reads an image from a buffer.
static std::optional< std::string > generateMipMaps (CesiumGltf::ImageAsset &image)
 Generate mipmaps for this image.
static bool unsafeResize (const std::byte *pInputPixels, int32_t inputWidth, int32_t inputHeight, int32_t inputStrideBytes, std::byte *pOutputPixels, int32_t outputWidth, int32_t outputHeight, int32_t outputStrideBytes, int32_t channels)
 Resize an image, without validating the provided pointers or ranges.
Definition at line 40 of file ImageDecoder.h.
◆ generateMipMaps()
static std::optional< std::string > CesiumGltfReader::ImageDecoder::generateMipMaps ( CesiumGltf::ImageAsset & image)
static
Does nothing if mipmaps already exist or the compressedPixelFormat is not GpuCompressedPixelFormat::NONE.
imageThe image to generate mipmaps for. *
A string describing the error, if unable to generate mipmaps.
◆ readImage()
static ImageReaderResult CesiumGltfReader::ImageDecoder::readImage ( const std::span< const std::byte > & data,
const CesiumGltf::Ktx2TranscodeTargets & ktx2TranscodeTargets )
static
The stb_image library is used to decode images in JPG, PNG, TGA, BMP, PSD, GIF, HDR, or PIC format.
dataThe buffer from which to read the image.
ktx2TranscodeTargetsThe compression format to transcode KTX v2 textures into. If this is std::nullopt, KTX v2 textures will be fully decompressed into raw pixels.
The result of reading the image.
◆ unsafeResize()
static bool CesiumGltfReader::ImageDecoder::unsafeResize ( const std::byte * pInputPixels,
int32_t inputWidth,
std::byte * pOutputPixels,
int32_t channels )
static
pInputPixelsThe input image.
inputWidthThe width of the input image, in pixels.
inputHeightThe height of the input image, in pixels.
inputStrideBytesThe stride of the input image, in bytes. Stride is the number of bytes between successive rows.
pOutputPixelsThe buffer into which to write the output image.
outputWidthThe width of the output image, in pixels.
outputHeightThe height of the otuput image, in pixels.
outputStrideBytesThe stride of the output image, in bytes. Stride is the number of bytes between successive rows.
channelsThe number of channels in both the input and output images.
True if the resize succeeded, false if it failed.
