GltfReader.h
3#include <CesiumAsync/AsyncSystem.h>
4#include <CesiumAsync/Future.h>
5#include <CesiumAsync/HttpHeaders.h>
6#include <CesiumAsync/IAssetAccessor.h>
7#include <CesiumGltf/Model.h>
8#include <CesiumGltfReader/GltfSharedAssetSystem.h>
9#include <CesiumGltfReader/Library.h>
10#include <CesiumImage/ImageAsset.h>
11#include <CesiumImage/ImageDecoder.h>
12#include <CesiumImage/Ktx2TranscodeTargets.h>
13#include <CesiumJsonReader/IExtensionJsonHandler.h>
14#include <CesiumJsonReader/JsonReaderOptions.h>
15
16#include <functional>
17#include <memory>
18#include <optional>
19#include <span>
20#include <string>
21#include <vector>
22
24
28struct CESIUMGLTFREADER_API GltfReaderResult {
32 std::optional<CesiumGltf::Model> model;
33
37 std::vector<std::string> errors;
38
42 std::vector<std::string> warnings;
43};
44
50struct CESIUMGLTFREADER_API MeshPrimitiveModeOptions {
55 bool convertLineStrip = false;
60 bool convertLineLoop = false;
72 bool convertTriangleFan = false;
73};
74
166
170class CESIUMGLTFREADER_API GltfReader {
171public:
176
181
186
195 const std::span<const std::byte>& data,
196 const GltfReaderOptions& options = GltfReaderOptions()) const;
197
211 const std::span<const std::byte>& data,
212 const CesiumAsync::AsyncSystem& asyncSystem,
213 const CesiumAsync::HttpHeaders& headers,
214 const std::shared_ptr<CesiumAsync::IAssetAccessor>& pAssetAccessor,
215 const std::string& baseUrl = {},
216 const GltfReaderOptions& options = GltfReaderOptions()) const;
217
231 const std::span<const std::byte>& data,
232 const CesiumAsync::AsyncSystem& asyncSystem,
233 const std::vector<CesiumAsync::IAssetAccessor::THeader>& headers,
234 const std::shared_ptr<CesiumAsync::IAssetAccessor>& pAssetAccessor,
235 const std::string& baseUrl = {},
236 const GltfReaderOptions& options = GltfReaderOptions()) const;
237
250 const CesiumAsync::AsyncSystem& asyncSystem,
251 const std::string& url,
252 const std::vector<CesiumAsync::IAssetAccessor::THeader>& headers,
253 const std::shared_ptr<CesiumAsync::IAssetAccessor>& pAssetAccessor,
254 const GltfReaderOptions& options = GltfReaderOptions()) const;
255
263 void
265
279 const CesiumAsync::AsyncSystem& asyncSystem,
280 const std::string& baseUrl,
281 const CesiumAsync::HttpHeaders& headers,
282 const std::shared_ptr<CesiumAsync::IAssetAccessor>& pAssetAccessor,
283 const GltfReaderOptions& options,
284 GltfReaderResult&& result);
285
290 [[deprecated("Use ImageDecoder::readImage instead.")]] static CesiumImage::
291 ImageReaderResult
293 const std::span<const std::byte>& data,
294 const CesiumImage::Ktx2TranscodeTargets& ktx2TranscodeTargets);
295
300 [[deprecated("Use ImageDecoder::generateMipMaps instead.")]] static std::
301 optional<std::string>
303
304private:
306};
307
308} // namespace CesiumGltfReader
A system for managing asynchronous requests and tasks.
Definition AsyncSystem.h:37
Definition Future.h:29
GltfReaderResult readGltf(const std::span< const std::byte > &data, const GltfReaderOptions &options=GltfReaderOptions()) const
Reads a glTF or binary glTF (GLB) from a buffer.
GltfReader()
const CesiumJsonReader::JsonReaderOptions & getExtensions() const
static CesiumAsync::Future< GltfReaderResult > resolveExternalData(const CesiumAsync::AsyncSystem &asyncSystem, const std::string &baseUrl, const CesiumAsync::HttpHeaders &headers, const std::shared_ptr< CesiumAsync::IAssetAccessor > &pAssetAccessor, const GltfReaderOptions &options, GltfReaderResult &&result)
Accepts the result of readGltf and resolves any remaining external buffers and images.
static std::optional< std::string > generateMipMaps(CesiumImage::ImageAsset &image)
Generate mipmaps for this image.
void postprocessGltf(GltfReaderResult &readGltf, const GltfReaderOptions &options)
Performs post-load processing on a glTF. The specific operations performed are controlled by the prov...
CesiumAsync::Future< GltfReaderResult > loadGltf(const CesiumAsync::AsyncSystem &asyncSystem, const std::string &url, const std::vector< CesiumAsync::IAssetAccessor::THeader > &headers, const std::shared_ptr< CesiumAsync::IAssetAccessor > &pAssetAccessor, const GltfReaderOptions &options=GltfReaderOptions()) const
Reads a glTF or binary glTF file from a URL and resolves external buffers and images.
CesiumAsync::Future< GltfReaderResult > readGltfAndExternalData(const std::span< const std::byte > &data, const CesiumAsync::AsyncSystem &asyncSystem, const CesiumAsync::HttpHeaders &headers, const std::shared_ptr< CesiumAsync::IAssetAccessor > &pAssetAccessor, const std::string &baseUrl={}, const GltfReaderOptions &options=GltfReaderOptions()) const
Read a glTF or binary glTF (GLB) from a buffer and then resolve external references.
CesiumAsync::Future< GltfReaderResult > readGltfAndExternalData(const std::span< const std::byte > &data, const CesiumAsync::AsyncSystem &asyncSystem, const std::vector< CesiumAsync::IAssetAccessor::THeader > &headers, const std::shared_ptr< CesiumAsync::IAssetAccessor > &pAssetAccessor, const std::string &baseUrl={}, const GltfReaderOptions &options=GltfReaderOptions()) const
static CesiumImage::ImageReaderResult readImage(const std::span< const std::byte > &data, const CesiumImage::Ktx2TranscodeTargets &ktx2TranscodeTargets)
Reads an Image from a buffer.
static CesiumUtility::IntrusivePointer< GltfSharedAssetSystem > getDefault()
Obtains an IntrusivePointer to the GltfSharedAssetSystem singleton.
std::map< std::string, std::string, CaseInsensitiveCompare > HttpHeaders
Http Headers that maps case-insensitive header key with header value.
Definition HttpHeaders.h:25
Definition GltfReader.h:23
Options for how to read a glTF.
Definition GltfReader.h:78
bool decodeEmbeddedImages
Whether embedded images in CesiumGltf::Model::buffers should be automatically decoded as part of the ...
Definition GltfReader.h:101
bool dequantizeMeshData
Whether the quantized mesh data are dequantized and converted to floating-point values when loading,...
Definition GltfReader.h:133
bool decodeDraco
Whether geometry compressed using the KHR_draco_mesh_compression extension should be automatically de...
Definition GltfReader.h:112
CesiumUtility::IntrusivePointer< GltfSharedAssetSystem > pSharedAssetSystem
Definition GltfReader.h:151
bool resolveExternalStructuralMetadata
Whether the schemaUri property of EXT_structural_metadata will be properly resolved....
Definition GltfReader.h:158
bool clearDecodedDataUrls
Whether data URLs should be cleared after they are successfully decoded.
Definition GltfReader.h:91
bool applyTextureTransform
Whether the texture coordinates of a texture are transformed or not, according to the KHR_texture_tra...
Definition GltfReader.h:139
bool decodeSpz
Whether gaussian splatting data are decompressed as part of the load process, or left in the compress...
Definition GltfReader.h:126
bool resolveExternalImages
Whether external images should be resolved.
Definition GltfReader.h:106
MeshPrimitiveModeOptions primitiveModeOptions
Options for handling values of CesiumGltf::MeshPrimitive::Mode that appear in a glTF mesh primitive.
Definition GltfReader.h:164
CesiumImage::Ktx2TranscodeTargets ktx2TranscodeTargets
For each possible input transmission format, this struct names the ideal target GPU-compressed pixel ...
Definition GltfReader.h:145
bool decodeMeshOptData
Whether the mesh data are decompressed as part of the load process, or left in the compressed format ...
Definition GltfReader.h:119
bool decodeDataUrls
Whether data URLs in buffers and images should be automatically decoded as part of the load process.
Definition GltfReader.h:83
The result of reading a glTF model with GltfReader::readGltf.
Definition GltfReader.h:28
std::optional< CesiumGltf::Model > model
The read model, or std::nullopt if the model could not be read.
Definition GltfReader.h:32
Errors, if any, that occurred during the load process.
Definition GltfReader.h:37
Warnings, if any, that occurred during the load process.
Definition GltfReader.h:42
Options for handling values of CesiumGltf::MeshPrimitive::Mode that appear in a glTF mesh primitive....
Definition GltfReader.h:50
Whether to convert CesiumGltf::MeshPrimitive::Mode::LINE_STRIP primitives to CesiumGltf::MeshPrimitiv...
Definition GltfReader.h:55
Whether to convert CesiumGltf::MeshPrimitive::Mode::LINE_LOOP primitives to CesiumGltf::MeshPrimitive...
Definition GltfReader.h:60
Whether to convert CesiumGltf::MeshPrimitive::Mode::TRIANGLE_FAN primitives to CesiumGltf::MeshPrimit...
Definition GltfReader.h:72
bool convertTriangleStrip
Whether to convert CesiumGltf::MeshPrimitive::Mode::TRIANGLE_STRIP primitives to CesiumGltf::MeshPrim...
Definition GltfReader.h:66
A 2D image asset, including its pixel data. The image may have mipmaps, and it may be encoded in a GP...
Definition ImageAsset.h:33
For each possible input transmission format, this struct names the ideal target gpu-compressed pixel ...
