NodeReader.h
5#include <CesiumGltf/Node.h>
9
10#include <rapidjson/fwd.h>
11
12#include <span>
13#include <vector>
14
15namespace CesiumGltf {
16struct Node;
17} // namespace CesiumGltf
18
20
24class CESIUMGLTFREADER_API NodeReader {
25public:
30
35
40
48 readFromJson(const std::span<const std::byte>& data) const;
49
57 readFromJson(const rapidjson::Value& value) const;
58
66 readArrayFromJson(const rapidjson::Value& value) const;
67
68private:
70};
71
CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Node > > readArrayFromJson(const rapidjson::Value &value) const
Reads an array of instances of Node from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< CesiumGltf::Node > readFromJson(const rapidjson::Value &value) const
Reads an instance of Node from a rapidJson::Value.
CesiumJsonReader::ReadJsonResult< CesiumGltf::Node > readFromJson(const std::span< const std::byte > &data) const
Reads an instance of Node from a byte buffer.
NodeReader()
Definition GltfReader.h:23
A node in the node hierarchy. When the node contains skin, all mesh.primitives MUST contain JOINTS_0 ...
Definition Node.h:25
Definition JsonReader.h:23
