Reads Node instances from JSON. More...
#include <CesiumGltfReader/NodeReader.h>
| NodeReader () | |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::Node > | readFromJson (const std::span< const std::byte > &data) const |
| Reads an instance of Node from a byte buffer. | |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::Node > | readFromJson (const rapidjson::Value &value) const |
| Reads an instance of Node from a rapidJson::Value. | |
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Node > > | readArrayFromJson (const rapidjson::Value &value) const |
| Reads an array of instances of Node from a rapidJson::Value. | |
Definition at line 24 of file NodeReader.h.
| CesiumJsonReader::ReadJsonResult< std::vector< CesiumGltf::Node > > CesiumGltfReader::NodeReader::readArrayFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::Node > CesiumGltfReader::NodeReader::readFromJson | ( | const rapidjson::Value & | value | ) | const |
| CesiumJsonReader::ReadJsonResult< CesiumGltf::Node > CesiumGltfReader::NodeReader::readFromJson | ( | const std::span< const std::byte > & | data | ) | const |
