LabelCollection#add
Throws:
eyeOffset : Cartesian3
Gets and sets the 3D Cartesian offset applied to this label in eye coordinates. Eye coordinates is a left-handed coordinate system, where
x
points towards the viewer's right,y
points up, andz
points into the screen. Eye coordinates use the same scale as world and model coordinates, which is typically meters.
fillColor : Color
// Use a top, right origin l.horizontalOrigin = Cesium.HorizontalOrigin.RIGHT; l.verticalOrigin = Cesium.VerticalOrigin.TOP;
outlineColor : Color
pixelOffset : Cartesian2
Gets or sets the pixel offset in screen space from the origin of this label. This is commonly used to align multiple labels and billboards at the same position, e.g., an image and text. The screen space origin is the top, left corner of the canvas;
x
increases from left to right, andy
increases from top to bottom.
The label's origin is indicated by the yellow point.default
Gets or sets near and far pixel offset scaling properties of a Label based on the Label's distance from the camera. A label's pixel offset will be scaled between the
NearFarScalar#nearValue
andNearFarScalar#farValue
while the camera distance falls within the upper and lower bounds of the specifiedNearFarScalar#near
. Outside of these ranges the label's pixel offset scaling remains clamped to the nearest bound. If undefined, pixelOffsetScaleByDistance will be disabled.Examples:
// Example 1. // Set a label's pixel offset scale to 0.0 when the // camera is 1500 meters from the label and scale pixel offset to 10.0 pixels // in the y direction the camera distance approaches 8.0e6 meters. text.pixelOffset = new Cesium.Cartesian2(0.0, 1.0); text.pixelOffsetScaleByDistance = new Cesium.NearFarScalar(1.5e2, 0.0, 8.0e6, 10.0);
// Example 2. // disable pixel offset by distance text.pixelOffsetScaleByDistance = undefined;
position : Cartesian3
Gets or sets the uniform scale that is multiplied with the label's size in pixels. A scale of
1.0
does not change the size of the label; a scale greater than1.0
enlarges the label; a positive scale less than1.0
shrinks the label.
Applying a large scale value may pixelate the label. To make text larger without pixelation, use a larger font size when callingLabel#font
instead.
From left to right in the above image, the scales are0.5
,1.0
, and2.0
style : LabelStyle
Gets or sets near and far translucency properties of a Label based on the Label's distance from the camera. A label's translucency will interpolate between the
. Outside of these ranges the label's translucency remains clamped to the nearest bound. If undefined, translucencyByDistance will be disabled.Examples:
// Example 1. // Set a label's translucencyByDistance to 1.0 when the // camera is 1500 meters from the label and disappear as // the camera distance approaches 8.0e6 meters. text.translucencyByDistance = new Cesium.NearFarScalar(1.5e2, 1.0, 8.0e6, 0.0);
// Example 2. // disable translucency by distance text.translucencyByDistance = undefined;
Computes the screen-space position of the label's origin, taking into account eye and pixel offsets. The screen space origin is the top, left corner of the canvas;
x
increases from top to bottom.Name Type Description scene
Scene The scene the label is in. result
Cartesian2 optional The object onto which to store the result. Returns:
The screen-space position of the label.Example:
Name Type Description other
Label The label to compare for equality. Returns:
true
if the labels are equal; otherwise,false
If this object was destroyed, it should not be used; calling any function other thanisDestroyed
will result in aDeveloperError
exception.Returns:
