Cesium for Unreal 2.31.0
#include <CesiumPropertyTextureProperty.h>
| static ECesiumPropertyTexturePropertyStatus | GetPropertyTexturePropertyStatus (UPARAM(ref) const FCesiumPropertyTextureProperty &Property) |
| Gets the status of the property texture property. | |
| static ECesiumMetadataBlueprintType | GetBlueprintType (UPARAM(ref) const FCesiumPropertyTextureProperty &Property) |
| Gets the best-fitting type for the property that is accessible from Blueprints. | |
| static ECesiumMetadataBlueprintType | GetArrayElementBlueprintType (UPARAM(ref) const FCesiumPropertyTextureProperty &Property) |
| Gets the best-fitting Blueprints type for the elements in this property's array values. | |
| static FCesiumMetadataValueType | GetValueType (UPARAM(ref) const FCesiumPropertyTextureProperty &Property) |
| Gets the type of the metadata value as defined in the EXT_structural_metadata extension. | |
| static int64 | GetArraySize (UPARAM(ref) const FCesiumPropertyTextureProperty &Property) |
| Gets the number of elements in an array of this property. | |
| static int64 | GetGltfTextureCoordinateSetIndex (UPARAM(ref) const FCesiumPropertyTextureProperty &Property) |
| Gets the glTF texture coordinate set index used by the property texture property. | |
| static int64 | GetUnrealUVChannel (const UPrimitiveComponent *Component, UPARAM(ref) const FCesiumPropertyTextureProperty &Property) |
| Gets the UV channel containing the texture coordinate set that is used by the property texture property on the given component. | |
| static TArray< int64 > | GetChannels (UPARAM(ref) const FCesiumPropertyTextureProperty &Property) |
| Get the channels array of this property. | |
| static uint8 | GetByte (UPARAM(ref) const FCesiumPropertyTextureProperty &Property, const FVector2D &UV, uint8 DefaultValue=0) |
| Attempts to retrieve the value at the given texture coordinates as an unsigned 8-bit integer. | |
| static int32 | GetInteger (UPARAM(ref) const FCesiumPropertyTextureProperty &Property, const FVector2D &UV, int32 DefaultValue=0) |
| Attempts to retrieve the value at the given texture coordinates as a signed 32-bit integer. | |
| static int64 | GetInteger64 (UPARAM(ref) const FCesiumPropertyTextureProperty &Property, const FVector2D &UV, int64 DefaultValue=0) |
| Attempts to retrieve the value for the given feature as a signed 64-bit integer. | |
| static float | GetFloat (UPARAM(ref) const FCesiumPropertyTextureProperty &Property, const FVector2D &UV, float DefaultValue=0.0f) |
| Attempts to retrieve the value at the given texture coordinates as a single-precision floating-point number. | |
| static double | GetFloat64 (UPARAM(ref) const FCesiumPropertyTextureProperty &Property, const FVector2D &UV, double DefaultValue=0.0) |
| Attempts to retrieve the value at the given texture coordinates as a double-precision floating-point number. | |
| static FIntPoint | GetIntPoint (UPARAM(ref) const FCesiumPropertyTextureProperty &Property, const FVector2D &UV, const FIntPoint &DefaultValue) |
| Attempts to retrieve the value at the given texture coordinates as a FIntPoint. | |
| static FVector2D | GetVector2D (UPARAM(ref) const FCesiumPropertyTextureProperty &Property, const FVector2D &UV, const FVector2D &DefaultValue) |
| Attempts to retrieve the value at the given texture coordinates as a FVector2D. | |
| static FIntVector | GetIntVector (UPARAM(ref) const FCesiumPropertyTextureProperty &Property, const FVector2D &UV, const FIntVector &DefaultValue) |
| Attempts to retrieve the value at the given texture coordinates as a FIntVector. | |
| static FVector | GetVector (UPARAM(ref) const FCesiumPropertyTextureProperty &Property, const FVector2D &UV, const FVector &DefaultValue) |
| Attempts to retrieve the value at the given texture coordinates as a FVector. | |
| static FVector4 | GetVector4 (UPARAM(ref) const FCesiumPropertyTextureProperty &Property, const FVector2D &UV, const FVector4 &DefaultValue) |
| Attempts to retrieve the value at the given texture coordinates as a FVector4. | |
| static FCesiumPropertyArray | GetArray (UPARAM(ref) const FCesiumPropertyTextureProperty &Property, const FVector2D &UV) |
| Attempts to retrieve the value for the given texture coordinates as a FCesiumPropertyArray. | |
| static FCesiumMetadataValue | GetValue (UPARAM(ref) const FCesiumPropertyTextureProperty &Property, const FVector2D &UV) |
| Retrieves the value of the property for the given texture coordinates. | |
| static FCesiumMetadataValue | GetRawValue (UPARAM(ref) const FCesiumPropertyTextureProperty &Property, const FVector2D &UV) |
| Retrieves the raw value of the property for the given feature. | |
| static bool | IsNormalized (UPARAM(ref) const FCesiumPropertyTextureProperty &Property) |
| Whether this property is normalized. | |
| static FCesiumMetadataValue | GetOffset (UPARAM(ref) const FCesiumPropertyTextureProperty &Property) |
| Gets the offset of this property. | |
| static FCesiumMetadataValue | GetScale (UPARAM(ref) const FCesiumPropertyTextureProperty &Property) |
| Gets the scale of this property. | |
| static FCesiumMetadataValue | GetMinimumValue (UPARAM(ref) const FCesiumPropertyTextureProperty &Property) |
| Gets the minimum value of this property. | |
| static FCesiumMetadataValue | GetMaximumValue (UPARAM(ref) const FCesiumPropertyTextureProperty &Property) |
| Gets the maximum value of this property. | |
| static FCesiumMetadataValue | GetNoDataValue (UPARAM(ref) const FCesiumPropertyTextureProperty &Property) |
| Gets the "no data" value of this property, as defined by its class property. | |
| static FCesiumMetadataValue | GetDefaultValue (UPARAM(ref) const FCesiumPropertyTextureProperty &Property) |
| Gets the default value of this property, as defined by its class property. | |
| static PRAGMA_DISABLE_DEPRECATION_WARNINGS FString | GetSwizzle (UPARAM(ref) const FCesiumPropertyTextureProperty &Property) |
| Get the string representing how the metadata is encoded into a pixel color. | |
| static int64 | GetComponentCount (UPARAM(ref) const FCesiumPropertyTextureProperty &Property) |
| Get the component count of this property. | |
Definition at line 133 of file CesiumPropertyTextureProperty.h.
static |
If the property is not an array type, this returns an empty array.
For numeric array properties, the raw array value for a given coordinates will be transformed by the property's normalization, scale, and offset before it is further converted. If the raw value is equal to the property's "no data" value, then the property's default value will be converted if possible. If the property-defined default value cannot be converted, or does not exist, then the user-defined default value is returned.
| Property | The property texture property. |
| UV | The texture coordinates. |
static |
If the given property does not contain array values, this returns None.
static |
Only applicable when the property is a fixed-length array type.
static |
For the most precise representation of the values possible in Blueprints, you should retrieve it using this type.
static |
For numeric properties, the raw value for the given coordinates will be transformed by the property's normalization, scale, and offset before it is further converted. If the raw value is equal to the property's "no data" value, then the property's default value will be converted if possible. If the property-defined default value cannot be converted, or does not exist, then the user-defined default value is returned.
Property values are converted as follows:
In all other cases, the user-defined default value is returned. If the property texture property is somehow invalid, the user-defined default value is returned.
| DefaultValue | The default value to fall back on. |
static |
This contains the indices of the meaningful texel channels that will be used when sampling the property texture.
static |
Since the metadata is encoded as pixel color, this is also the number of meaningful channels it will use.
static |
This default value is used use when encountering a "no data" value in the property.
If a default value is not defined, this returns an empty value.
static |
static |
static |
This is the index N corresponding to the "TEXCOORD_N" attribute on the glTF primitive that samples this texture.
If the property texture property is invalid, this returns -1.
static |
static |
Although property texture properties do not directly support 64-bit integers, this can be used to losslessly retrieve values from unsigned 32-bit integer properties.
For numeric properties, the raw value for a given feature will be transformed by the property's normalization, scale, and offset before it is further converted. If the raw value is equal to the property's "no data" value, then the property's default value will be converted if possible. If the property-defined default value cannot be converted, or does not exist, then the user-defined default value is returned.
static |
In all other cases, the user-defined default value is returned. In all vector cases, if any of the relevant components cannot be represented as a 32-bit signed, the default value is returned.
static |
In all other cases, the user-defined default value is returned. In all vector cases, if any of the relevant components cannot be represented as a 32-bit signed integer, the default value is returned.
static |
This can be defined by the class property that it implements, or overridden by the instance of the property itself.
This is only applicable to scalar, vecN and matN properties. It represents the component-wise maximum of all property values with normalization, offset, and scale applied. If a maximum value is not defined or applicable, this returns an empty value.
static |
This is only applicable to scalar, vecN and matN properties. It represents the component-wise minimum of all property values with normalization, offset, and scale applied. If a minimum value is not defined or applicable, this returns an empty value.
static |
This value functions a sentinel value, indicating missing data wherever it appears. The value is compared against the property's raw data, without normalization, offset, or scale applied.
This is not applicable to boolean properties. If a "no data" value is not defined or applicable, this returns an empty value.
static |
This is only applicable to properties with floating-point or normalized integer component types. If an offset is not defined or applicable, this returns an empty value.
static |
If this property texture property is invalid in any way, this will briefly indicate why.
static |
This is the value of the property without normalization, offset, or scale applied.
If this property specifies a "no data" value, and the raw value is equal to this "no data" value, the value is returned as-is.
static |
This is only applicable to properties with floating-point or normalized integer component types. If a scale is not defined or applicable, this returns an empty value.
static |
This is useful to unpack the correct order of the metadata components from the pixel color.
static |
This refers to the UV channel it uses on the primitive's static mesh, which is not necessarily equal to value of GetGltfTextureCoordinateSetIndex.
This function may be used with FindCollisionUV to get the feature ID from a line trace hit. However, in order for this function to work, the feature ID texture should be listed under the CesiumFeaturesMetadataComponent of the owner Cesium3DTileset. Otherwise, its texture coordinate set may not be included in the Unreal mesh data. To avoid using CesiumFeaturesMetadataComponent, use GetFeatureIDFromHit instead.
This returns -1 if the property texture property is invalid, or if the specified texture coordinate set is not present in the component's mesh data.
| Component | The component to get the texture coordinate set from. |
static |
This allows the value to be acted on more generically; its true value can be retrieved later as a specific Blueprints type.
For numeric properties, the raw value for a given feature will be transformed by the property's normalization, scale, and offset before it is returned. If the raw value is equal to the property's "no data" value, an empty value will be returned. However, if the property itself specifies a default value, then the property-defined default value will be returned.
static |
Many of these types are not accessible from Blueprints, but can be converted to a Blueprint-accessible type.
static |
In all other cases, the user-defined default value is returned. In all vector cases, if any of the relevant components cannot be represented as a single-precision float, the default value is returned.
static |
static |
static |
Only applicable when this property has an integer component type.
