CesiumMetadataValueType.h File Reference
#include "CesiumMetadataEnum.h"
#include <CesiumGltf/Enum.h>
#include <CesiumGltf/PropertyArrayView.h>
#include <CesiumGltf/PropertyType.h>
#include "CesiumMetadataValueType.generated.h"
Classes
struct  FCesiumMetadataValueType
 Represents the true value type of a metadata value, akin to the property types in EXT_structural_metadata. More...
Namespaces
namespace  Cesium3DTiles
Enumerations
enum class  ECesiumMetadataBlueprintType : uint8 {
  None , Boolean , Byte , Integer ,
  Integer64 , Float , Float64 , IntPoint ,
  Vector2D , IntVector , Vector3f , Vector3 ,
  Vector4 , Matrix , String , Array
 The Blueprint type that can losslessly represent values of a given property. More...
enum class  ECesiumMetadataTrueType_DEPRECATED : uint8 {
  None_DEPRECATED = 0 , Int8_DEPRECATED , Uint8_DEPRECATED , Int16_DEPRECATED ,
  Uint16_DEPRECATED , Int32_DEPRECATED , Uint32_DEPRECATED , Int64_DEPRECATED ,
  Uint64_DEPRECATED , Float32_DEPRECATED , Float64_DEPRECATED , Boolean_DEPRECATED ,
  Enum_DEPRECATED , String_DEPRECATED , Array_DEPRECATED
 The type of a metadata property in EXT_feature_metadata. More...
enum class  ECesiumMetadataPackedGpuType_DEPRECATED : uint8 { None_DEPRECATED , Uint8_DEPRECATED , Float_DEPRECATED }
enum class  ECesiumMetadataType : uint8 {
  Invalid = 0 , Scalar = int(CesiumGltf::PropertyType::Scalar) , Vec2 = int(CesiumGltf::PropertyType::Vec2) , Vec3 = int(CesiumGltf::PropertyType::Vec3) ,
  Vec4 = int(CesiumGltf::PropertyType::Vec4) , Mat2 = int(CesiumGltf::PropertyType::Mat2) , Mat3 = int(CesiumGltf::PropertyType::Mat3) , Mat4 = int(CesiumGltf::PropertyType::Mat4) ,
  Boolean = int(CesiumGltf::PropertyType::Boolean) , String = int(CesiumGltf::PropertyType::String) , Enum = int(CesiumGltf::PropertyType::Enum)
 The type of a metadata property in EXT_structural_metadata. More...
enum class  ECesiumMetadataComponentType : uint8 {
  None = 0 , Int8 = int(CesiumGltf::PropertyComponentType::Int8) , Uint8 = int(CesiumGltf::PropertyComponentType::Uint8) , Int16 = int(CesiumGltf::PropertyComponentType::Int16) ,
  Uint16 = int(CesiumGltf::PropertyComponentType::Uint16) , Int32 = int(CesiumGltf::PropertyComponentType::Int32) , Uint32 = int(CesiumGltf::PropertyComponentType::Uint32) , Int64 = int(CesiumGltf::PropertyComponentType::Int64) ,
  Uint64 = int(CesiumGltf::PropertyComponentType::Uint64) , Float32 = int(CesiumGltf::PropertyComponentType::Float32) , Float64 = int(CesiumGltf::PropertyComponentType::Float64)
 The component type of a metadata property in EXT_structural_metadata. More...
◆ ECesiumMetadataBlueprintType
strong
Enumerator
None
Boolean
Byte
Integer
Integer64
Float
Float64
IntPoint
Vector2D
IntVector
Vector3f
Vector3
Vector4
Matrix
String
Array
Definition at line 21 of file CesiumMetadataValueType.h.
◆ ECesiumMetadataComponentType
strong
Only applicable if the property has a Scalar, VecN, or MatN type.
Enumerator
None
Int8
Uint8
Int16
Uint16
Int32
Uint32
Int64
Uint64
Float32
Float64
Definition at line 125 of file CesiumMetadataValueType.h.
◆ ECesiumMetadataPackedGpuType_DEPRECATED
strong
Enumerator
None_DEPRECATED
Uint8_DEPRECATED
Float_DEPRECATED
Definition at line 96 of file CesiumMetadataValueType.h.
◆ ECesiumMetadataTrueType_DEPRECATED
strong
This has been deprecated; use FCesiumMetadataValueType to get the complete type information of a metadata property instead.
Enumerator
None_DEPRECATED
Int8_DEPRECATED
Uint8_DEPRECATED
Int16_DEPRECATED
Uint16_DEPRECATED
Int32_DEPRECATED
Uint32_DEPRECATED
Int64_DEPRECATED
Uint64_DEPRECATED
Float32_DEPRECATED
Float64_DEPRECATED
Boolean_DEPRECATED
Enum_DEPRECATED
String_DEPRECATED
Array_DEPRECATED
Definition at line 76 of file CesiumMetadataValueType.h.
◆ ECesiumMetadataType
strong
Enumerator
Invalid
Scalar
Vec2
Vec3
Vec4
Mat2
Mat3
Mat4
Boolean
String
Enum
Definition at line 106 of file CesiumMetadataValueType.h.
