Cesium for Unreal 2.31.0
A base component interface for interacting with metadata in a Cesium3DTileset. More...
#include <CesiumMetadataComponent.h>
| void | SyncStatistics () |
| Syncs this component's statistics description from its tileset owner, retrieving values for the corresponding semantics. | |
| bool | IsSyncing () const |
| Whether a sync is already in progress. | |
| void | InterruptSync () |
| Interrupts any sync happening on this component. | |
| virtual void | OnFetchMetadata (ACesium3DTileset *pActor, const Cesium3DTilesSelection::TilesetMetadata *pMetadata) |
| Event that occurs once metadata is successfully synced from the tileset during SyncStatistics. | |
| virtual void | ClearStatistics () |
| Called during various parts of the sync process. | |
| virtual void | OnRegister () override |
Definition at line 20 of file CesiumMetadataComponent.h.
protectedvirtual |
Derived classes must override this.
Reimplemented in UCesiumFeaturesMetadataComponent.
| void UCesiumMetadataComponent::InterruptSync | ( | ) |
Usually called before destroying or refreshing a tileset.
| bool UCesiumMetadataComponent::IsSyncing | ( | ) | const |
protectedvirtual |
Derived classes must override this to make use of the results.
overrideprotectedvirtual |
| void UCesiumMetadataComponent::SyncStatistics | ( | ) |
If there are described statistics that are not present on the tileset owner, they will be left as null values.
