Cesium for Unreal
2.31.0
CesiumMetadataComponent.h
1
// Copyright 2020-2026 CesiumGS, Inc. and Contributors
3
#pragma once
5
#include "Components/ActorComponent.h"
6
#include "CesiumMetadataComponent.generated.h"
9
class
ACesium3DTileset
10
11
namespace
Cesium3DTilesSelection
12
class
TilesetMetadata
13
14
15
16
* @brief A base component interface for interacting with metadata in a
17
* Cesium3DTileset.
18
19
UCLASS(ClassGroup = Cesium,
Meta
= (BlueprintSpawnableComponent))
20
class CESIUMRUNTIME_API
UCesiumMetadataComponent
: public UActorComponent {
21
GENERATED_BODY()
22
23
public
24
25
* Syncs this component's statistics description from its tileset owner,
26
* retrieving values for the corresponding semantics.
27
28
* If there are described statistics that are not present on the tileset
29
* owner, they will be left as null values.
30
31
void
SyncStatistics
32
33
34
* Whether a sync is already in progress.
35
36
bool
IsSyncing
const
37
38
39
* Interrupts any sync happening on this component. Usually called before
40
* destroying or refreshing a tileset.
41
42
void
InterruptSync
43
44
protected
45
46
* Event that occurs once metadata is successfully synced from the tileset
47
* during SyncStatistics. Derived classes must override this to make use of
48
* the results.
49
50
virtual
void
OnFetchMetadata
51
ACesium3DTileset
* pActor,
52
const
Cesium3DTilesSelection::TilesetMetadata
* pMetadata);
53
54
55
* Called during various parts of the sync process. Derived classes must
56
* override this.
57
58
virtual
void
ClearStatistics
59
60
// Called when a component is registered. This seems to be the best way to
61
// intercept when the component is pasted (to then update its statistics).
62
virtual
void
OnRegister
override
63
64
private
65
bool
_syncInProgress;
66
Meta
Meta
Definition
CesiumVoxelMetadataComponent.h:58
ACesium3DTileset
Definition
Cesium3DTileset.h:104
A base component interface for interacting with metadata in a Cesium3DTileset.
Definition
CesiumMetadataComponent.h:20
UCesiumMetadataComponent::SyncStatistics
void SyncStatistics()
Syncs this component's statistics description from its tileset owner, retrieving values for the corre...
UCesiumMetadataComponent::OnRegister
virtual void OnRegister() override
UCesiumMetadataComponent::IsSyncing
bool IsSyncing() const
UCesiumMetadataComponent::ClearStatistics
virtual void ClearStatistics()
UCesiumMetadataComponent::InterruptSync
void InterruptSync()
UCesiumMetadataComponent::OnFetchMetadata
virtual void OnFetchMetadata(ACesium3DTileset *pActor, const Cesium3DTilesSelection::TilesetMetadata *pMetadata)
Event that occurs once metadata is successfully synced from the tileset during SyncStatistics.
Source
CesiumRuntime
Public
Generated by
1.13.2
