Cesium for Unreal 2.31.0
A component that can be added to Cesium3DTileset actors to dictate what feature ID sets or metadata to encode for access on the GPU. More...
#include <CesiumFeaturesMetadataComponent.h>
| void | RefreshStyle () |
| Reapplies the Blueprint style specified in BlueprintStyleClass to the tileset. | |
| virtual PRAGMA_ENABLE_DEPRECATION_WARNINGS void | PostLoad () override |
| UObject * | GetStyleInstance () const |
| Gets the instance of BlueprintStyleClass that has been created to style features in this tileset. | |
Public Member Functions inherited from UCesiumMetadataComponent | |
| void | SyncStatistics () |
| Syncs this component's statistics description from its tileset owner, retrieving values for the corresponding semantics. | |
| bool | IsSyncing () const |
| Whether a sync is already in progress. | |
| void | InterruptSync () |
| Interrupts any sync happening on this component. | |
| TSubclassOf< UObject > | BlueprintStyleClass |
| The Blueprint class to instantiate for feature styling. | |
| FCesiumFeaturesMetadataDescription | Description |
| Description of both feature IDs and metadata from a glTF via the EXT_mesh_features, EXT_instance_features, and EXT_structural_metadata extensions. | |
| PRAGMA_DISABLE_DEPRECATION_WARNINGS TArray< FCesiumFeatureIdSetDescription > | FeatureIdSets |
| Description of the feature ID sets in the visible glTF primitives across the tileset. | |
| TSet< FString > | PropertyTextureNames |
| Names of the property textures used by the glTF primitives across the tileset. | |
| TArray< FCesiumPropertyTableDescription > | PropertyTables |
| Descriptions of the property tables in the visible glTF models across the tileset. | |
| TArray< FCesiumPropertyTextureDescription > | PropertyTextures |
| Descriptions of property textures in the visible glTF models across the tileset. | |
| virtual void | OnFetchMetadata (ACesium3DTileset *pActor, const Cesium3DTilesSelection::TilesetMetadata *pMetadata) override |
| Event that occurs once metadata is successfully synced from the tileset during SyncStatistics. | |
| virtual void | ClearStatistics () override |
| Called during various parts of the sync process. | |
Protected Member Functions inherited from UCesiumMetadataComponent | |
| virtual void | OnRegister () override |
"Add Properties" allows users to find and select desired feature ID sets and metadata properties. Once a selection is made, "Generate Material" can be used to auto-generated the boiler-plate code to access the selected properties in the Unreal material.
Definition at line 24 of file CesiumFeaturesMetadataComponent.h.
overrideprotectedvirtual |
Derived classes must override this.
Reimplemented from UCesiumMetadataComponent.
If no BlueprintStyleClass was specified, this will be null.
This function may be used to modify variables on the instance of the style at runtime.
Definition at line 181 of file CesiumFeaturesMetadataComponent.h.
Derived classes must override this to make use of the results.
overridevirtual |
| void UCesiumFeaturesMetadataComponent::RefreshStyle | ( | ) |
Use this function to pick up any changes to the Blueprint in-Editor as well as its instance at runtime.
| TSubclassOf<UObject> UCesiumFeaturesMetadataComponent::BlueprintStyleClass |
This is used for any feature ID sets with StylingMode set to Blueprint.
Definition at line 77 of file CesiumFeaturesMetadataComponent.h.
| FCesiumFeaturesMetadataDescription UCesiumFeaturesMetadataComponent::Description |
Indicates what parts of the extension should be uploaded to the GPU for access in Unreal materials.
Definition at line 104 of file CesiumFeaturesMetadataComponent.h.
| PRAGMA_DISABLE_DEPRECATION_WARNINGS TArray<FCesiumFeatureIdSetDescription> UCesiumFeaturesMetadataComponent::FeatureIdSets |
Definition at line 121 of file CesiumFeaturesMetadataComponent.h.
| TArray<FCesiumPropertyTableDescription> UCesiumFeaturesMetadataComponent::PropertyTables |
Definition at line 148 of file CesiumFeaturesMetadataComponent.h.
| TSet<FString> UCesiumFeaturesMetadataComponent::PropertyTextureNames |
This should be a subset of the property textures listed in the model metadata. Property textures can be passed to the material even if they are not explicitly used by a glTF primitive, but the primitive may lack the corresponding sets of texture coordinates intended to sample them.
Definition at line 137 of file CesiumFeaturesMetadataComponent.h.
| TArray<FCesiumPropertyTextureDescription> UCesiumFeaturesMetadataComponent::PropertyTextures |
Definition at line 159 of file CesiumFeaturesMetadataComponent.h.
