CustomDepthParameters.h
5#include <Components/PrimitiveComponent.h>
6#include <CoreMinimal.h>
8#include "CustomDepthParameters.generated.h"
9
10USTRUCT(BlueprintType)
11struct CESIUMRUNTIME_API FCustomDepthParameters {
12 GENERATED_USTRUCT_BODY()
13
14public:
15 /** If true, this component will be rendered in the CustomDepth pass (usually
16 * used for outlines) */
17 UPROPERTY(
18 EditAnywhere,
19 AdvancedDisplay,
20 BlueprintReadOnly,
21 Category = Rendering,
22 meta = (DisplayName = "Render CustomDepth Pass"))
23 bool RenderCustomDepth = false;
24
25 /** Mask used for stencil buffer writes. */
26 UPROPERTY(
27 EditAnywhere,
28 AdvancedDisplay,
29 BlueprintReadOnly,
30 Category = "Rendering",
31 meta = (EditCondition = "RenderCustomDepth"))
32 ERendererStencilMask CustomDepthStencilWriteMask =
33 ERendererStencilMask::ERSM_Default;
34
35 /** Optionally write this 0-255 value to the stencil buffer in CustomDepth
36 * pass (Requires project setting or r.CustomDepth == 3) */
37 UPROPERTY(
38 EditAnywhere,
39 AdvancedDisplay,
40 BlueprintReadOnly,
41 Category = Rendering,
42 meta = (UIMin = "0", UIMax = "255", EditCondition = "RenderCustomDepth"))
44
45 bool operator==(const FCustomDepthParameters& other) const {
46 return RenderCustomDepth == other.RenderCustomDepth &&
47 CustomDepthStencilWriteMask == other.CustomDepthStencilWriteMask &&
48 CustomDepthStencilValue == other.CustomDepthStencilValue;
49 }
50
51 bool operator!=(const FCustomDepthParameters& other) const {
52 return !(*this == other);
53 }
54};
int32 CustomDepthStencilValue
Optionally write this 0-255 value to the stencil buffer in CustomDepth pass (Requires project setting...
bool operator!=(const FCustomDepthParameters &other) const
If true, this component will be rendered in the CustomDepth pass (usually used for outlines)
