CesiumSubLevel.h
5#include "CoreMinimal.h"
6#include "GameFramework/Actor.h"
7#include "CesiumSubLevel.generated.h"
9class ULevelStreaming;
10
11struct UE_DEPRECATED(
12 5.0,
13 "The FCesiumSubLevel struct has been deprecated. Use Level Instance Actors and UCesiumSubLevelComponent instead.")
15
16/*
17 * Sublevels can be georeferenced to the globe by filling out this struct.
18 */
19USTRUCT()
21 GENERATED_BODY()
22
23 /**
24 * The plain name of the sub level, without any prefixes.
25 */
26 UPROPERTY(VisibleAnywhere, Category = "Cesium")
27 FString LevelName;
28
29 /**
30 * Whether this sub-level is enabled. An enabled sub-level will be
31 * automatically loaded when the camera moves within its LoadRadius and
32 * no other levels are closer, and the Georeference will be updated so that
33 * this level's Longitude, Latitude, and Height bcome (0, 0, 0) in the Unreal
34 * World. A sub-level that is not enabled will be ignored by Cesium.
35 *
36 * If this option is greyed out, check that World Composition is enabled
37 * in the World Settings and that this sub-level is in a Layer that has
38 * Distance-based streaming DISABLED.
39 */
40 UPROPERTY(
41 EditAnywhere,
42 Category = "Cesium",
43 Meta = (EditCondition = "CanBeEnabled"))
44 bool Enabled = true;
45
46 /**
47 * The WGS84 latitude in degrees of where this level should sit on the globe,
48 * in the range [-90, 90]
49 */
50 UPROPERTY(
51 EditAnywhere,
52 Category = "Cesium",
53 meta = (ClampMin = -90.0, ClampMax = 90.0, EditCondition = "Enabled"))
54 double LevelLatitude = 0.0;
55
56 /**
57 * The WGS84 longitude in degrees of where this level should sit on the
58 * globe, in the range [-180, 180]
59 */
60 UPROPERTY(
61 EditAnywhere,
62 Category = "Cesium",
63 meta = (ClampMin = -180.0, ClampMax = 180.0, EditCondition = "Enabled"))
64 double LevelLongitude = 0.0;
65
66 /**
67 * The height in meters above the WGS84 globe this level should sit.
68 */
69 UPROPERTY(
70 EditAnywhere,
71 Category = "Cesium",
72 meta = (EditCondition = "Enabled"))
73 double LevelHeight = 0.0;
74
75 /**
76 * How far in meters from the sublevel local origin the camera needs to be to
77 * load the level.
78 */
79 UPROPERTY(
80 EditAnywhere,
81 Category = "Cesium",
82 meta = (ClampMin = 0.0, EditCondition = "Enabled"))
83 double LoadRadius = 0.0;
84
85 UPROPERTY(VisibleDefaultsOnly, Category = "Cesium")
86 bool CanBeEnabled = false;
87};
The WGS84 latitude in degrees of where this level should sit on the globe, in the range [-90,...
bool Enabled
The WGS84 longitude in degrees of where this level should sit on the globe, in the range [-180,...
double LevelHeight
double LoadRadius
How far in meters from the sublevel local origin the camera needs to be to load the level.
FString LevelName
